Magnetic rotar Wind Turbine
Started by glassman, October 06, 2008, 02:02:12 PM
Dave45
So if I took a vawt turned it on its side mounted it in the back of my truck where only the top portion raised above the cab I figure I could run at least two pmg's - one on each side
The pmg's could be the bearings for the vawt one on each end.
Its doable
I guess turning it on its side it wouldnt be considered a vertical axis wind turbine but this  gives you guys an idea
Dave45
So a pmg in a 30 mh wind will putout about 40 amps
Two pmg's should pump 80 amps into a battery bank.
That should extend the range of a ev.
Pirate88179
Quote from: Dave45 on May 19, 2015, 05:08:34 PM
But, you also have to factor in the aerodynamic drag, which would be considerable if the device is under load as in an EV.
Dave45
Hey Bill
Yes all windmills have drag and most are under load ie charging battery's.
I think a vawt would have more aerodynamic drag standing out in the open than it would mounted in the bed of a truck.
Wind dividers show an improvement with the vawt and this is the reason.
Pirate88179
Quote from: Dave45 on May 19, 2015, 09:24:03 PM
Hey Bill
OK, good picture, now I see what you are getting at.  This position would seem to reduce the wind braking effects that a vertical mount would have.  In other words, like this, it is more like a water wheel with very little opposing wind forces.
