Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
sparks
   There is an electrochemcial reaction going on in the spark gap.  Nitrogen and Oxygen are combiing to form nitrates.  Lightning is a scource of nitrates.  Nitrates are not good for corona discharge equipment as they are conductive therefore ozone producing equipment has oxygen seperators upstream of the very large surface area spark gaps.  Nitrogen and oxygen combining is an exothermic process.  When this process takes place in the presence of a magnetic field the excess thermal energy takes on the form of electron acceleration along a common path.  The electrostatic potential of the confined orbiting free electrons is radiated.  The spark gap becomes a monopolar negatively charged mass field.  Free electrons on the surface of a copper conductor are accelerated away from the spark gap and an electrostatic induced current insues in the primary winding from the oxidation of nitrogen.  The spark gap is then cleared of the conducting nitrates and new fuel is brought in.  Tesla himself tried setting up his spark gaps in evacuated tubes and found the results disappointing.  Nitrates are only returned to nitrogen and oxygen in endothermic chemical reactions.  They are the basic ingredients in fertilizers.  The nitrogen cycle is very important as most of our atmosphere is comprised of it.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
baroutologos
@Del boy,
Believe whatever you want dude. Biffilar coils are not suited for tesla coils. Period. Those are the worst kinf of coils. But as receivers, they can be actually used if they possess the peculiar properties they are attributed at.
I am familiar with Tesla Coils actual designs. This way Tesla achieved Qs of tens of thousands. So? You have a million volts... you have more power out? You have also a great current displacement... You have power?
Who told you that? Any proof? We are all speculating here
@Forest,
more or less that's the idea Tito suggests, and its according Kapanadze speculative technology also... A high Q resonator or Tesla coil to amplify small voltage/current levels via resonance (this way we have virtual power of pf=0) and a biffilar (or triffilar) setup for pulsing and power harvesting
Magluvin
Im speculating here. Tito said he went on vacation. Then delboy arrives pretty much the next day,new. Delboy reminds me of tito a bit but a little different.   ;)
mags
ramset
Mags
mags
Could be the Erfinder connection[another I know but won't tell fellah]
I had the same thought!
Hopefully Teetums is sunnin himself on some beach down by you.
Chet
PS
Anybody have a link to Erfinder's site?
Lost in a crash!
Thanks Grandma
Tito L. Oracion
Quote from: delboy on February 28, 2010, 03:26:48 AM
Why are you expecting someone to tell you secret??? Why are you focusing on bifilar when it is designed for coils for electromagnets not for TeslaCoil? Tesla newer draw any bifilar coil for Tesla Coil! Ask Tesla ! You are speaking about some receivers but no one is mentioning Tesla longitudinal voltage receiver like in patent 685955 or in 787412 !
Problem in working that receiver which is not sensitive one, is that you need to create big enogh disturbance in Earth. How to do that?? Well build one TeslaCoil like he had one :D You have to have HIGH VOLTAGE AND HIGH FREQUNCY to have enough voltage per meter of length so you can operate receiver!
If you don't want transfer throgh Earth but only localy over some wire, just connect transmiter directly with receiver.
Everybody are building some TeslaCoils and when you compare them with Tesla they look stupid!
For example, everybody are building TeslaCoil with secondar with several thosand turns and diameter max 20cm but Tesla had one with 50 turns spiral wound and diameter 244cm and developed 2-4 mega volts, and compare that with results today in TeslaCoil practice :D You have wrong instructions for TeslaCoil !!! His secondary was cable No8 or diameter of 3,2mm giving 8,3 square milimeters and having resistance only 2 Ohms per kilometer of length! Compare that with todays TC with secondar with wire No32 or diameter 0,2mm having resistance 538 Ohms per kilometer length! How can you have AMPLIFICATION if resistance is HIGH. AMPLIFICATION is Q factor of coil which is inversly proportional to resistance !!! When it was no longer practical to give rise to diameter of wire Tesla introduced cooling the wire to very low temperatures (-200°C) to have even bigger AMPLIFICATION because resistance is falling down with temperature (see patent 685012)! His primary was only one turn cable consisting of 37xNo9 giving aprox 244 square milimeters! How can you than expect to have good working receiver if you don't have good transmiter?
And one message to ERFINDER : Thank you for everything you pushed me in right direction, I can drive now by my own.
Hi every body goodday  ;D
greetings! happy day happy summer happy easter happy holloween merry christmas and happy new year!
this is the crazy guy of overunity dot.com now signing on!  ;D
how is everybody!
is there something new,
well i'm getting weird everyday  ;D
first i'm not BELBOY OK. look at me closely i'm little bit handsome  ;D and bellboy  :-[
hi del boy just a joke, welcome to the family  ;D
do you know that I don't actually need a transmitter for my receiver?  ???
do not focus on a primary use of a bifi, everything has a lot of use we have to discover their different use ok.
No! amplification is not! a Q factor of coil ok. amplification is a by product of collapsing magnetic field of an energized capacitor! discharge.  from a ____ and ____ circuit 8)   ;D
well what you are talking is our current system, there why i can't blaime you.
yes i would like to thank also erfinder for opening one of my eye.   ;)   ;D  ;D  ;D  ;D lol
