Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
bboj
I agree with Barth. regarding overunity.
Tesla is talking about allmost 100% efficiency which I think is amazing.
Whatever you put in the sistem remains there and performs work.
sparks
  A is neither created nor destroyed but it can be focused or magnified.  The below diagram takes a thermodynamic flow from hot to cold and changes it to oscillating mass movement.  The energy flow through the system is unidirectional but the effect on mass is not.  The gas valve in this diagram could be operated at very high frequency allowing for an alternating flow of the liquid driven by a unidirectional flow of energy.  By  capturing the head pressure in the cold resevoir we double the efficiency of the system.  If the liquid just went through the turbine and then was released to the atmosphere the return stroke work would not be performed.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Qwurky1
Sure this is super obvious and I'm singing to the choir, but the reason devices like the magnifying transmitter will never be allowed to surface is simple: it would completely change the entire world's socioeconomic structure, enabling cheap desalinization of seawater, irrigation of crops, and the lifting of the "third world" to equal status.  Not to sound like your typical whiny econuts, but big oil, big power, big auto, and big government have absolutely no reason to allow such equality.  Today's world structure is completely derived from darwinian economics... the strong can exploit the weak because they are stronger than the weak, obviously either God or Nature intended for them to be the inheritor of the earth, and the rest of us are only incidental rejects, only of use for exploitation and labor.  k wow that was sorta preachy.  Sorry.  Power to the People!  Viva Tesla!
delboy
Quote from: gyulasun on May 02, 2010, 02:08:12 PM
There is one sentence Tesla wrote that may shed some light if the receivers consume or does not consume from the plant he keeps the Earth in vibration with:
In other words, if I have a 10,000 horsepower plant, it would take only 100 horsepower to keep the earth vibrating so long as there is no energy taken out at any other place.
How did he mean it? if I take out energy from the vibration by my receivers, then I have to supply more at my transmitter site to make up for it?
My present understanding is that I have to...
You don't understand it do you? Plant of 10 000 horse power (or 7,5MW) is power in secondary of TC because that is output from plant! You have minimum and maximum available power in secondary of TC. Tesla is talking that you have to design your TC that it will be able to give at least 100 horse power, so to keep Earth in vibration! If you connect receivers , TC will automaticaly self-adjust to give more energy.
Tesla used bigger coils with bigger wire diameter and bigger coil diameter, that is why he had so big available energy. Just go and calculate your small TC, be happy if you get 100 horse power to keep Earth in vibration :D
gyulasun
Quote from: delboy on July 18, 2010, 12:44:09 PM
Hi Delboy,
Thanks for returning to this topic. I understood it because I also wrote I had to supply more power to the transmitter (i.e. TC) if somewhere on Earth receivers were switched on to tap the Earth vibration.
You wrote (I made in bold letters above) if energy is received i.e. taken from the vibration, then the TC will give automatically more energy.
Now please explain where this more energy comes from? Do I have to pump it into the TC so that it should make up for the Earth vibrational energy tapped by the receivers? The more receivers are in operation, the more input energy I have to enter into the TC?
This is the question I have not found an answer from Tesla's writings.
Thanks,  Gyula
