Cosmic Lattice
Started by orbs, October 10, 2008, 02:53:43 PM
Trino Cularoid
Quote from: orbs on October 10, 2008, 02:53:43 PMIt always takes the same amount of time for energy to transverse the internal distance of one lattice cell.
As in (quantum) tunneling. See, for example, Nimtz/Haibel: Zero Time Space [5.3.4 and 1] (German: Tunneleffekt - Räume ohne Zeit [5.1.2 und 1]).  <-- click on links
Trino Cularoid
giantkiller
The first 2 posts on this thread were all that are needed to understand the bigger picture. Feel secure that the providers of this information choose not to point the magnifying glass on our ant hill.
The rest is all human concoction.
Do more reading of Russell, Tesla, Dollard, Keely, Shauberger, Leedskalnin. Then the posts will be riveting.
Dialectricity...
QuoteHere's how it works. Two magnetic fields together, postured in the correct way -- a way that is very three-dimensional in your thinking process -- will create a "designed magnetic field" that is very specific. It's one you have never seen, and does not exist naturally. Start with trying many magnetics fields, postured against one another -- of unequal force and pattern, and at right angles. Don't make any assumptions. Think freely. Done in the right fashion, these two fields will create a third pattern, which is unique and is the product of the original two. This third custom created pattern is the one you what to deal with, and is the one that has the potential of manipulating the lattice. Once you have created it, you will know of its special qualities by how dramatically it changes the physics around it. It won't be subtle in its exposition -- believe me. You will know when you have it.
Here is a caution. Keep this experiment away from your body! Keep the experiment in check with your scientific methods. Go slowly. Understand what you're seeing before you go to the next step. Do not expose yourself to any magnetic fields. Remotely conduct all energy experiments. Remember that magnetics also plays an important part within your body.
... Product of the GK4.
--giantkiller.
Rosphere
Quote from: orbs on October 10, 2008, 02:56:53 PM
...The Universe as you know it is pasted upon the inside and the outside of this toroidal tube. You look out and see the Universe as a shape that suits your expected reality. You don't see the curves, since light is supposed to travel in a straight line. It doesn't... it never has. In an interdimensional paradigm, you could be looking at something where the light from an object comes to you through a convoluted, twisting path, but within your 4D reality, you would swear that it was a "straight shot" to the object, since this is what you expect to see. The truth lies within a scope of reality outside what you expect or have experienced, so it's tough to describe it to you...
I have experienced an optical illusion in the sky: The perpendicular bisector of the half-moon sun/shade line does not appear to intersect the sun.  What?
Whenever the moon is presenting at, or near, the half-phase and both the moon and the sun are visible in the sky, I think about what is causing the shadow on the moon.  It is not the Earth, (outside of ecliptic times,) so I reason that the moon is causing it's own shadow; the dark side of the moon.
Continuing this line of thought, I try to eyeball a straight line in the sky upon which I expect the sun must lie in order to cause the moon shadow to appear at the angle at which it does to me here on Earth.
That straight line that I visualize in the sky never intersects the sun!  This freaked me out a little when I first observed it.  I rationed that I was like a fish looking out of the water, in that I was looking out of the atmosphere, with the same sort of light bending between mediums thing happening between our atmosphere and space that happens between water and air.
So then I imagine that I am inside of a giant drop of water.  I imagine my straight line in the sky bending toward the sun from the perpendicular bisector of the moon shadow.  (I recall the line always bending down, toward the horizon... I think,... I will need to recheck.)
My point is, light rays traveling between two points within our own solar system, (sun to moon,) do appear to follow "a convoluted, twisting path, within your 4D reality," and I can not even "swear that it was a 'straight shot' to the object."  I have not the means at this time to change my point of view.
This is an interesting read.  I hope that I can get through it this weekend; it is too thought provoking to read quickly.
EDIT: I've finished.
We can only tell you this much.  We are not sure what to make of it.  We have told you that much.
What's with all the theatrics?
