Cosmic Lattice
Started by orbs, October 10, 2008, 02:53:43 PM
orbs
Quote from: vonwolf on October 11, 2008, 02:17:51 PM[...] if the vast amount of energy from Gravity that is bled off into a unknown dimension could be harnessed for pracical use we would have hit the lotto.
That would be interesting. However, is gravity bleeding from our particular 3 dimensions, or is it the other way round, it is bleeding into ours? My understanding is that above texts suggest the latter...
vonwolf
Quote from: orbs on October 11, 2008, 02:30:01 PM
Yes that may be true that's why I said it only seemed like string therory. One of the many things String Therory try's to explain is why somethig as massive as gravity has such a relatively weak force? Its all Theory any way
atomicX
Scientist got into all kind of problems and make up all kinds of theory because they don't have an equation for energy.  I don't have a problem seeing the atom as the sun earth system.  Quantum mechanic got a problem because the electron is stable and does not spiral to the center, and if it doesn't where does the energy comes from.  Oh geez, where does the energy from the sun comes from.  I say the sun got powered by planets.  Of course you don't have to take my world for it.  People ignore static force as it has nothing to do with energy.   This is where science collapse.  They can't define energy right.
Your indicated 3.force is the nuclear/nucleus force    -Kern-Kraft- , is it not ?
CdL
orbs
Quote from: lancaIV on October 26, 2008, 10:23:04 PMYour indicated 3.force is the nuclear/nucleus force    -Kern-Kraft- , is it not ?
Those would be a "pair" of the commonly accepted fundamental interactions already, if I understand you correctly.
[Es mag etwas verwirrend sein, weil man die Grundkräfte der Physik üblicherweise nicht in Paaren zählt. Die Idee ist also, 6 anstatt nur die bisher bekannten 4 Kräfte zu haben, wobei die 2 neuen nur sehr selten direkt nachweisbar sind, weil sie sich in "unseren" 3 Dimensionen die meiste Zeit über "gegenseitig" aufheben.]
