RAVZZ circuit : parts list w/ values?
Started by frog, October 10, 2008, 03:56:03 PM
frog
I see some have altered the docs to show 100 ohm resistors on the pots? Not sure why they are needed as my cell
functions w/o them..anyone have an idea why they are on some docs and not others? I have also noticed docs showing zeners
off the FET, and have read this is for FET protection incase of short circuit...
"When you change the way you look
at things, the things you look at change."
frog
Also some other observations:
I had to run my power from my switching DC power supply into a bridge rectifier then to my lawton circuit, I was getting a gawd awful
high pitched "noise" from the power supply when connected to the lawton circuit...? I do NOT have enough electronics
knowledge to troubleshoot that...or to use an o-scope for that matter.. But I can let the smoke out of components pretty
good now...I think I have mastered that part, I didn't know that components ran on smoke, and when you let it out they
stop working? How can I put more smoke back into the circuits than I let out? Is this even possible? Is it over unity? :)
ashtweth_nihilisti
frog the docs were updated in order to be more stable and also under instruction from Dave, the latest ones is what you shod model off and what Ravzz doc is modeled off. I suggest you seek out any one local who is in to electronics to help you on your way, its a very slow process, but think of the rewards
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Farlander
The 100ohm resistors next to the pots are to keep your chip from blowing up like mine did when I removed them... it maintains a minimum resistance across that part of the circuit.
Where is this next document with 9 inductors on it?
ashtweth_nihilisti
