HHO Cell - Stan Meyer Design.
Started by peterpierre, October 11, 2008, 05:01:21 PM
What do you think about my current findings in regards to my interpretation of Stanley Meyers System?
I think you're right on track.
Should work but I have reservations. (please post explanation)
I think you're way off. (please post explanation)
xinmogg
Hey Peterpierre,
I am getting a bit worried about you. After following this topic for some weeks I got really anxious too read about your results. Now your deadline has well passed and you have stopped posting for a while ??? Are you still with us? Is there any help you could use with finishing your experiment?
I`m keeping my fingers crossed for your success ! And please drop a line or two if you can to give us an update.
Cheers,
Xinmogg
Zipster
In hope Peterpierre is not in jail for beating up his woman or dead from being severely electrocuted, here is a link that might help his business.
http://jnaudin.free.fr/wfc/index.htm
peterpierre
Alright guys, sorry bout me disappearing again on you - I am not in jail - haven't beaten up anybody (you just don't do things like that - especially not to a woman) ... electrocuted I am not either, contrair to common beliefs and no ... I did not get arrested or killed by any government or oil company - however I have kept on going with my work and finally there is light at the end of the tunnel - it is very hard to hold all ends together especially with me being in a new country now and stuff. Anyways the electronics turned out to be quite a bit more complex than my initial assumptions permitted me to imagine. The pulse train pattern is very complex and has to be compensated (almost constantly) and you have to compensate for distortions in the pattern cause through induction coupling - still - stan meyer is very accurate on the fact that voltage does the work, however that VIC is also far more complex than the actual schematic suggests because just a ferrite ring core transformer doesn't cut it quite - there is much more to it but with some help from the people I am working with we have been puzzling the whole thing together without much talk and publicity, so the results as originaly promised will be delivered - as soon as present :) Looking good guys - sometimes keeping your mouth shut or lying (if necessary) through your teeth might make the difference between succeeding or failing miserably, for all of you who are bound for success in matters of free energy, just try to mimic the strategies the US government uses in order to hide or twist things ... might be very helpful :)
Gauss
I would like to suggest to all Stan Meyer experimenters to try very soft rubber spacers(3 each at the top and bottom) and a free hanging cell in the electric cables, the SS316L cylinders must be allowed to vibrate. Use no coils, just pulse the cell with at least 2.5 Volts 50% duty cycle square wave. Use distilled water. You will get HHO, it is that simple, check for yourself.
I call it vibralysis and I suspect Meyer´s work is all about vibration of crystals and acoustic tuning. The HV and low amps are needed to drive the crystal(s) or actuator(s)..
peterpierre
I thank you for your suggestion - I appreciate it but ultimately it comes too late because I cracked the math on the system already and it does exactly what it should be doing and with deepest regret must point out to you that you got the whole process completely wrong interpreted, but as I always like to say - nice try :)
