Silicon Salt Battery
Started by Thaelin, October 16, 2008, 08:08:19 PM
Thaelin
Hi all:
   Starting to see reference to this new type of battery but can find no real info on it.
I am converting an E-Bike and this extra punch would help out on distance. Thanks
thaelin
jeanna
This is very interesting. I wonder what the chemistry is.
Some links promised to tell, but I didn't see any chemistry info.
This sodium aluminate should be easy to get from clay which is mostly just that sodium/aluminum/silicates.
Do you have the info to publish here to make this easy, Thaelin?
thank you,
jeanna
Thaelin
   Sadly no I have nothing to go on at the moment. I did hear that an e-bike company
in germany ships it with this type of battery. All the battery companies here in the
US have no info on them or heard of them.  :(
thaelin
  Maybe Stephan has a lead???
jeanna
OK I will study up a little to refresh.
I am pretty sure the lead acid battery has one kind of lead in a paste squished into a grid made of lead of another type and the sulphuric acid makes the reaction. I have never seen the explanation that "sticks".
This question gives me good reason to really look for it.
So, then for now conceptually at least, I suppose that with these 2 kinds of lead still in place, the Na/Al//Si in this alkaline environment will react with the lead and give it new life? maybe as some reports said, more peppy.
I'll have a look.
Maybe someone else can help?
jeanna
resonanceman
Quote from: jeanna on October 17, 2008, 02:18:14 PM
Jeanna
A paste is not always used .
I remember around  15 or 20 years ago  they switched  the  stuff they add to the plates .   at  the time thecalled batterys with the   new  chemistry   "low maintanance "
Another   variation is  the  optima  battery .   It  has  its  plates in the form  of a  mats  of lead  threads .
the  mats are  sandwiched   between  layers of  fiberglass ......the  whole thing is  rolled up into  a  cylinder  .  Because   the  plates are  tightly  rolled between  layers of fiberglass   the plates themselves need little or no mechanical  strength  so the  chemistry  can be optimised   for  electrical   properties rather than a combination of  electrical and mechanical   properties .
Optima  batterys  cost   around  3 times more than  regular batterys  but  are said to last  4 times longer .   Mine is  4 years old  and  seems  to be as good as new .
gary
There  is  only one  small  vent  on my  optima  and no place where water could be added .
