Hydrogen Peroxide Helicopter Intora Firebird
Started by khabe, October 21, 2008, 05:42:42 PM
khabe
Hydrogen peroxide is compatible with two metals: aluminum and stainless steel.
What will happend when it meats some rust? -> Kursk !!!
regards,
khabe
khabe
Cheap Hydrogen Production        ->    http://www.unexplained-mysteries.com/forum/lofiversion/index.php/t42773.html
Mechanism of H2O to H2O2:
Radiation can directly interact with a molecule and damage it directly. Because of the abundance of water in the body, radiation is more likely to interact with water. When radiation interacts with water, it produces labile chemical species (free radicals) such as hydronium (H.) and hydroyxls (.OH). Free radicals can produce compounds such as hydrogen peroxide (H2O2) which subsequently exert chemical toxicity.
respect,
khabe
Yucca
Quote from: khabe on November 05, 2008, 05:33:22 AM
Hydrogen Peroxide Car
http://www.whynot.net/ideas/3903
peace,
khabe
Retrofitting existing cars for H2O2 is an interesting idea. I think if you could somehow fit a tiny silver catalyst pack just after the injector of a normal diesel engine, like a small tube on the injector outlet that contains silver wool then running on 90% H2O2 should be easy with good power output. Also you shouldn´t have to worry about the steel cylinder walls getting corroded because it would only be H2O and O2 in the chamber. You could have aluminium pipes suppying the H2O2 to the injectors, may have to use an old aluminium beer keg or something like that for the tank. If the injectors did suffer from corrosion then aluminium and stainless injectors could be fabricated.
I can´t think of any real problems with the idea, certainly sounds like the energy density of H2O2 is fairly good (50% energy density of burning gasoline) in fact I think you would get more MPG with H2O2 car because we all know combution is not efficient in gas engines, wheras H2O2 going through catalyst is 100% conversion. You could maybe even do away with the cooling system.
Imagine the exhaust after cooling through the silencer you would get a dribble of pure clean water and a good stream of pure oxygen gas, cities would then be the place to walk for anyone with lung conditions.
Yucca.
khabe
Yeah, you right - rust & corrodes are extremely danger when H2O2 ...
My main interest is micro powerplant:
making cheaply H2O2  ->->-> turbine -> el. generator  + heat used as much as possible,
Cheers,
khabe
