Hydrogen Generator with heavy duty CPVC Mason Jar lids
Started by bandr60, October 24, 2008, 04:01:06 PM
What do you think of this design?
your thoughts
2 (40%)
do you like what you see?
3 (60%)
Total Members Voted: 5
bandr60
I recently started making heavy-duty generator lids for wide mouth mason jars,
These allow me to add more plates to my generators and prevents from any leaking, cracking etc.
Please feel free to visit my Website at www.hydro-extra.webs.com.
I have tried numerous designs, and still feel that the mason jar offers less maintenance, mason jars are transparent so you can see what is going on inside your generator, the glass doesn't break down from thermal expansion from the elevated temperatures and temperature change, they take the heat well and they are easy and inexpensive to replace.
The only problem was trying to find a lid that would be durable enough, well now there’s one available.
My lids have a high temperature gasket that give a 100% seal and withstand the temperatures.
The hose and terminal connections are all drilled and tapped, with a little Teflon tape they seal great.
My generators are capable of producing 1 to 1-1/4 liters per minute of hydrogen.
Definitely worth checking out.
www.hydro-extra-webs.com
jdcmusicman
looks like little hydrogen grenades if ask me ....Let one of these get a good flashback and you will have sharp glass shards flying everywhere , making hydrogen in glass is dangerous....
kewlhead
Quote from: jdcmusicman on October 24, 2008, 09:56:03 PM
I dont think anybody's stupid enuf to try and light a torch with it but ya never know....   you probably shuld " note - not ment for producing flames "  there are some pretty silly ppl out there that never heard "curriosity killed the cat" and might just try to fame the output instead of its intended purpose.
jdcmusicman
I wasn't talking about lighting a flame to it , I was talking bout having a flashback , which you will have those from time to time , thats why I wouldn't use glass ....
bandr60
Wouldn't matter if it was plastic, acrylic, or PVC pipe. If it was to explode, but of all the kits I've used or have seen as long as you use some type of flashback arrester you are pretty safe.
But I agree! you can never be to safety conscious. When using hydrogen safety goggles and long sleeves probably makes most sense.
Also full knowledge and research of operation prior to installing a system.
You definitely wouldn't want to go at this blind.
