Sticky Tape X-Rays
Started by Rosphere, October 24, 2008, 11:03:18 PM
nul-points
hi Rosphere
excellent find!
here's an experiment you CAN try at home, boys and girls ...without needing an expensive vacuum generator & X-Ray scintillation sensor equipment
when you receive a letter which has a self-adhesive envelope, open it in the dark whilst holding the sticky-seal side towards you, pull the flap apart quickly, along the seal, and you should see the discharge flash
note that X-Rays may be released, so don't make a habit of this!
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
BEP
I wonder if this is related to the spark of light you have when crunching down on wintergreen LifeSaver candies?
Those of us using duct-tape to repair almost everything must now look forward to cancer  :'(
Someone should inform the cast and crew of the 'Red-Green Show' out of Canada  :D
pese
X-Ray and Nuc.
That is not the easiest way
Since Tesla times to generate X-Rays in a High-voltage-field in vacuum tubes (the blue-bright starting the X-ray discharge.
Each static high voltage can already generate X-rays.
"Damper- Diodes," by older TVs
are dangerous and were always used in older TV-sts.
DY802 and powerfullier GY501
(TV-tubes)  send considerable amounts of X-Ray and may 1000volts to 25,000 volts be operated This is the cheapest kind. No motors and vacuum mechanics problems.
A 5 DLS and power tube, + Hight Voltages . This is enought  for make an  X-ray set (as nearly 100 years before)
GP
pese
[ X-Ray and Nuc.
P.S. Pic was made with such an Vakuum Tube !
PESE
