half a volt from 1/16th of an inch.
Started by nitinnun, October 30, 2008, 05:18:20 AM
resonanceman
Quote from: professor on October 30, 2008, 02:45:42 PM
Hi,
I could not find the File that I downloaded a while ago perhaps of the Keely net, but this was a similar experiment ,which produced much higher voltages and if shorted out it recovered. Not a Battery in its sense but much more like a capacitor.
There were two plates I think of aluminum and sandwiched between them was a polymer Lexan or acrylic sheet of a thickness to withstand 30000 Volts. Clamped together and with 30000 volt DC applied to either side it was stuck into an oven and heated  to kind of melt the polymer onto the alu.plates After that it was removed from the oven still with its voltage connected and cooled.
After cooling the voltage was removed resulting in a selfcharging Device of high voltage.
Always wanted to try that,but never got around to it, therefore unable to confirm, I can not claim that it works.
professor
Professor
I think I read that  a long time ago .
I remember a warning  about  to much  power being  used while it is melting
The  resistance of the plastic  can  quickly drop  if  to much  power is used
It  looks like it works kind of like electrinium.
As I was writing  this I kept getting flashes  of a different   device .
http://energy21.freeservers.com/elecfg.htm
Adding  particles to  the  dielectric  as they  did  in the electron field generator   might  raise the output .
gary
nitinnun
this is what you were talking about, professor.
i think that the magnetic field and its iron core,
cause the cells positive charge to go to one pole,
and the negative charge to go to the other pole.
since the 2 charges leave the layers, to go to the iron poles,
the copper and aluminum atoms can dump MUCH more of their energy into the layers.
the polymer cell without the coil and iron core, is like a bucket of water that has a little hole in it.
only a little water can escape from the hole, over time.
when the coil is charged, and the coils magnetic field enters the iron,
it is like you ripped off the bottom of the bucket.
and ALL of the water is fallout out of the bucket.
resonanceman
nitinnun
In the link  in my last post  figure 3 shows  a way that I think  your cells  could be stacked .
gary
resonanceman
Quote from: nitinnun on October 30, 2008, 06:58:25 PM
nitinnun
I am  pretty sure that they are not the same .
It has been a while  but I think  I read about both  of  them  nearly the same time .
The  picture   on your  post  is suposed to be used in the testatica ...... the plastic  in it is uncooked .................................although ..........it  might  work better  if  the 2 devices  were combined
Cooking the plastic  AND  stimulating it with a magnetic field .
gary
resonanceman
Quote from: resonanceman on October 30, 2008, 06:54:44 PM
I can't  build it now .........but I would love to see a glue cell  made  with  particles  of  silicon carbide ( available  at  rock shops for  tumbling  rocks )  or  silica sand ..... ( ground up  quarts )
Another  thing  that would  be interesting is using  hot melt  glue  instead of elmers .
It  would give you  a  physically  stable  battery in   just a few minutes.
I read in a do it yourself  article  that  hot melt  glue is  one of the  best insulators for high  voltage  that  you can get
  gary
