Lynnferd Grant HHO Breakthrough
Started by goldenequity, November 14, 2008, 09:33:48 AM
goldenequity
Wanted to get this up!
More to discuss later!
Very interesting audio interview with Lynnferd Grant who has now produced gas not just AT the electrodes..
but BETWEEN them with a 3" separation.... a la Stanley Meyers.... no resonance, no tubes..... a paper clip.... and a spoon!
Download:
http://www.blogtalkradio.com/kywaterfuelmuseum/2008/11/14/Lynnferd-Grant.mp3
Listen:
Free Online Radio - Internet Talk Radio | BlogTalkRadio
gotoluc
Hi goldenequity,
Excellent find my friend ;) ... this could help tie many things together.
Thanks for starting this topic.
Luc
Jokker
Great find !
What about a video he told about ... ?
And ... as he talks ... seems easy, sure and interesting stuff. No kidding i just cant understand all, but seems he knows what he is talking about coz hes certain, straight, predictable and detailed during conversation. Next part is a result and yea he described this part as well guide well.
Sure it is worth trying. There is a very good reason, coz its something diffrent and yea replicating pulsed LCR circuit does not show results.
lynnferd@mail.com
-hes mail.
Buy the ticket !
Take the ride !
goldenequity
Here's some of the more pertinent (to HHO) dialog I extracted from the audio:  ;D
Quote"On video last night I showed that you have the cloud of bubbles forming between the electrodes, and one of the electrodes in the cup was nothing more than a 1" paperclip unfolded, a one inch length, and that's a very short piece of wire, and the other electrode in the 3" in diameter cup was a spoon, and when the ultrasonics was turned on, it's feeble shaking caused
"bubbles to form throughout the volume of water"
"You do that to the Meyer's fuel cell.... which is nothing more than having a high voltage potential across it, which I put there by putting the electrodes across the capacitor in a standard microwave, the magnatron's capacitor, which is having rather raw unfiltered DC, but nonetheless it is having high voltage DC about 2000 volts, in the range of what Meyer's would be talking about for making his cell work.
I am simply showing in this video... and anybody can do this extremely simply, by taking those two wires from across the capacitor in the microwave... very carefully, cause it's deadly voltage,... across the Meyer water fuel cell...which in its crudest form is a cup of distilled water.... and you have electrodes in there of some kind... he uses "pipes" ...but they're just surface electrodes.. and I showed in the video that you can use a paper clip for one electrode and a spoon for the other.... 3 inches across the large cup...and when you turn on the high voltage... raw AC ripple filtered, unfiltered DC that it does NOT...without the ultrasonic cavitation effect of ultrasonic cleaning...does not do anything... other than suggest a few feeble bubbles on the electrodes.... but when you turn on the ultrasonics, it causes the collapsing bubbles between the electrodes...which then go into a plasma and at that state ... James... and audience.. at that state the little "speck" of plasma behaves like an "inter" electrode.
At that billionth of a second.... that poor little spot...is becoming an electrode in an electrolysis condition... the voltage between the electrodes is divided in a voltage divider so that you have approximately 1.5 volts in the area of that little plasma spot....doing microscopic electrolysis... across that microscopic electrode which exists in an unfathomably small moment of time... a billionth of a second...BUT... you DO have electrolysis.
The phenomenon of ultrasonic cavitation is the bubble then immediately explodes.. because if you think a minute... this cycling process by going between almost a vacuum and a plasma.... if you study sonoluminescence... and I would suggest the broader issue of sonoplasma.... it is oscillating... so that little tiny dot of plasma... after it forms electrolysis on its surface... hydrogen on one side of the potential voltage gradient... and the oxygen on the other, it is immediately exploding... and therefore the hydrogen and oxygen do not get a chance to ... in the conventional sense.. to combine."
goldenequity
More...
Quote"Of course that's what Stanley Meyers was doing and you look at his videos on Youtube
and on an on.... and that people that have reproduced that effect have found it to be
fleeting.... and Meyers..Stanley Meyers talks about in his patent and his many discussions
and presentations and lectures before he had an untimely death ten years ago.. that it
was the resonant frequency of water.
And people are trying to find that.... and I am saying that today, as this simple explanation
I am giving that where you put the voltage..DC voltage gradient across distilled water and
introduce ultrasonic shaking where the ultrasonic waves are causing... like in bubble scrubbing
ultrasonic cleaners the bubbles exploding from a plasma state into a much larger bubble because
of the momentum of water.... and then if you read up on sonoluminesence.... the bubble is 50 (fifty)
times larger than it would be in its normal state.... and its nearly a vacuum at that point and
then the pressure wave comes through the water to greet this tiny little bubble during the
ultrasonic treatment of water... and then this bubble rapidly collapses... because after all its a
virtual vacuum at that stage... and then the momentum of the water will continue to push it
into a tiny little focal point... if the bubble is round.... which means it has to be small and
unaffected by gravity.
So this is what I was able to demonstrate by the introduction of ultrasonics to a cup of water
with the electrodes and the voltage gradient on it ... and it immediately formed the bubbles...
and increasingly....it was not a large set of bubbles... but it was mimicking Meyers fine bubbles..
something akin to the fine fizzy effect of carbonation.
And the little bubbles show us that we are after a NOT ACCIDENTAL RESONANCE of water and the
Meyers effect to get a massive amount of hydrogen from water.... but rather an ultrasonic.. which is
to inject to that frequency instead of accidently have your electrical pulses accidently shape
something into a transducer."
