The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
captainpecan
Quote from: nightlife on November 17, 2008, 01:15:53 AM
Voltage with amps = watts. Voltage without amps = no watts. Power is based on watts or joules per second. You must have a watt gain to have any gain at all.
You must not have worked much with capacitors. It's not the same. You would be correct, most cases I agree. But with capacitors, you measure total energy. Which is 1/2 * Capacitance * Voltage^2.  Yes, I mention only voltage early. But later I show what your concern is about. The total energy.
Thanks for your input though.
slapper
captainpecan; thank you.
Still trying to figure out how you got 2 to = (1.1 * 2) plus do a little work on the side.
Thanks again.
nap
we are not alone :)
captainpecan
Quote from: Michelinho on November 17, 2008, 01:03:59 AM
@captainpecan,
Nice work. I enjoyed the videos very much. Thanks.
Take care,
Michel
Thank you!  It's not easy trying to go head to head with 100's of years of physics. I did my best.
captainpecan
Quote from: slapper on November 17, 2008, 01:25:15 AM
Thanks again.
nap
Lol... I knew someone would be able to look past the equation crap and see the whole point of these video's... Good work...
capthook
Watched vid 4 again: your process is flawed
At the start you touch the leads of 3 capacitors together in hopes of getting a "control" figure.
You say "connecting them in parrallel with the least possible losses"
Again - I say the sparks flying when you do this is VERY lossy.
So comparing the 2nd test through the circuit - that is LESS lossy without all the sparks flying - as showing an energy gain is a flawed conclusion.
And you say "if you add the voltages together, which I say you can even though the equations say you can't"
That's your 2nd problem.
The equations are to determine an actual value of energy (joules : watts/second) - just adding the voltages to show a gain is wrong.
