Why does mass slow time?
Started by gravityblock, November 25, 2008, 05:31:30 AM
gravityblock
Quote from: brian334 on January 12, 2009, 04:19:02 PM
Does time have mass? No.
Does time have velocity? No.
Does time have any physical properties? No.
So how can time that does not have any physical properties cause things with physical properties to change?
The answer is it can not.
Blackholes destroy or removes space, energy, and matter from time. and inside the blackhole time creates space, mass, and energy within itself (other universes) . A permanent magnet is similar to a blackhole if not the same. You can either destroy or remove some of the "time", which creates space, energy, and particles (matter) or you can remove space, matter, and energy to create time.
You can either destroy or remove time to create a space within it or destroy the space to create time.
I am only using the word "destroy" for understanding purposes only. You can either convert time into space, or you can convert the space into time. This is what causes gravity. Gravity is the fluctuations of space within time or the fluctuations of time within space. Physics did get a few things right, although had to reword it differently for a better understanding.
Does time have velocity? Yes, it is a continuous (infinite) flow of time similar to a permanent magnet and has no space or mass within the magnetic field of flux. Light has a finite speed because the time is being delivered in packets, has space between the packets because it is not continuous flow of time.  A permanent magnet has the property of a continuous flow of time and there are no space (no mass) or breaks in the time. Thus it stops or blocks the flow of electrons along a conductor unless you keep moving the magnet. If you could add enough space or remove time in this continuous flow of energy (time) that is flowing within the magnetic field of flux (no space or mass), then it wouldn't cut the flow of electrons along the conductor as long as it was being delivered at or slower than the current flow. There is no space or mass within the magnetic field of flux.
Does time have any physical properties? Infinite Time is totally aware of itself and knows it has no physical properties, so it takes away from itself, which causes a break or a space in its flow, and this space is what we know to be in the physical world. If it allowed the break to be a longer duration, then their would be more space between time. In the beginning of creation, which has no beginning or end, there is no space or mass between time and time is aware of this, so it generates space or mass by varying the duration or the  frequency between this time, and in this physical world we see this as the frequencies of the electromagnet spectrum, which is known to us as energy, and is also responsible for all of the energy and matter we have in this physical world. The more energy or mass that is present within a given space the less time that is available to it, so it is not as aware of its existence, and when it reaches an infinite mass, then it has no time, and since it has no time, then it destroys itself and we see this destruction in the formation of a  black hole, and after it destroys itself, then it starts (the black hole will remove all space from time and once all of the space has been destroyed, then it will have infinite time, and then creates another universe. Infinite mass/energy destroys itself and Infinite time creates mass and energy. If you really study and try to wrap your mind around this concept, then you will understand it, and know who your creator is and the creator is totally aware of everything, and you can rest assured that you are loved, because out of infinite time comes love and all goodness.
This is the theory of everything, and everything comes out of the fluctuations of space and time. Since Time (God) has no beginning or end we should say everything comes out of time or God. God is the greatest mathematician and engineerer ever to be. Spiritual things are time, life, your awareness of yourself and of others and physical things are mass, energy, and space. When we lose are physical body we will become totally aware of ourselves and have infinite time, this is what most of the popular religions says and now it is proven with physics and science . Please do not murder yourself or others, for by doing so, you may destroy your own lifeforce or the lifeforce of others. I am not sure on this though, so don't take the chance. According to the bible this will lead to your own destruction. The bible refers of 2 different types of death, a physical death and a spiritual death. The books of the bible was given to us by God, and we all need to read it so we won't destroy our spiritual self, which is not existing in the physical form or the spiritual form.
If your not understanding this, then try to change your frame of reference to the creator or the universe. We've been looking at this from our frame of reference and we need to apply relativity to this.
Does infinite time have life? Yes
Does infinite mass/energy have life? No
For those who understand this, please try to help me put this in words so we may all have this understanding. This will unite all religions and sciences. Once you re-read the first chapter of the book of Genesis and apply this knowledge to it, you will know that God is real and that he knows each and every one of us, and we will know him also.
gravityblock
I started a new thread in the half baked section titled "The theory of everything" and it includes additional information. Please post your comments of this theory to the new thread. Thanks
http://www.overunity.com/index.php?topic=6559.0
PYRODIN123321
@Steven Dufresne-Thanks for the explanation,  ;D i watched your video with the cork and the strings, very cool trick..
i still need to do more research.....
how does a wave come in at all directions though? some sort of pressure wave, like being underwater and the pressure keeps going up and down?
ps: thought this was very interesting-can't get over it!
http://www.youtube.com/watch?v=XJk8ijAUCiI
Peace.
PYRODIN123321
@gravity
Hmmm....I am under the impression (right now anyways) that matter is a set of 2 or more waves (in what I'm not sure-time maybe) and it says in El bible that god 'SPOKE' and it was...now sound is a wave, so maybe god is not time but outside time and his voice is what is powering the whole shabang....time, atoms and the universe....I keep my mind open to new possibilities though...
on the other hand trying to figure out god and how he (or she or it) fits into the picture is kinda too big for me and can only help muddy the water, when we figure out how the universe and the atom, works, then we can address how god(or the divine force or whatever) did it....for now I'm content not understanding god so much, rather his beautiful work.
Not that I'm saying god isn't good and all, its just not practical.
Bringing God into any equation is an illogical means to an incorrect solution....1+2+God=X ;D
ps: are you a mason? just curious....
Peace.
Steven Dufresne
Quote from: PYRODIN123321 on January 14, 2009, 11:07:29 AM
You can imagine the twisting going on in my mind too as I had hours of fun trying to follow it.
Good question. The answer is, it doesn't.  ;D That's where Huygen's principle comes in:
http://en.wikipedia.org/wiki/Huygens_principle
See the attached animation I made a few months ago. It's a whole bunch of expanding circular waves and the resulting collapsing circular wavefront in the middle. Spherical waves involve simply adding a 3rd dimension. (IGNORE THE DOT AT THE CENTER; IT SHOULDN'T BE THERE! No discrete particles at the center in WSM  :)) So only a small portion of the out-wave of one particle interacts with and returns from another particle.
Very cool! You'll like this one too:
http://nz.youtube.com/watch?v=sY6z2hLgYuY
-Steve
http://rimstar.org   http://wsminfo.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
