Low Current HHO Production.
Started by Hydro-Cell, November 26, 2008, 11:40:39 AM
starcruiser
Interesting, so at 14 Lpm it can provide enough output to run a 12hp engine. This system could then run a 120V AC generator and produce from 10KW to 25Kw or more.
With the capability to adjust production, this would be good for a house system. So what is the electrolyte used in your design? Plain tap distilled or NaOH? (I am assuming NaOH).
Will you be trying this on a 5Kw or larger generator to test how long this can be run? Or have you done run tests already?
Regards,
Carl
Hydro-Cell
hi
solution is 30% KOH
14lpm runs the engine under the load required to run itself, hope that makes sense.  if more load were put on more hho is required.
i hope at some point to try this setup on a 1litre car engine. it has all the electronics and altrnator to run itself so the crankshaft can be used for output of energy. i.e a generator motor
ramset
Hydro are you talking about a tramsmitt er?
1000 watts on a dipole can make a lot of noise
if antennae tech is what you are doing have you tried parabolic [focus]
or creating the wave inside a resonant chamber?
Very interesting thankyou for sharing
can i get more info chetkremens@gmail.com
Thanks Grandma
starcruiser
@Hydro-Cell,
Cool. Do you have any Pix of the core/cell you can post?
Regards,
Carl
30 percent KOH.
So, just to be sure, you are putting in 300 grams of KOH pellets for every liter (1000 grams) of water.
Right?
