plasmacluster is electrolysis?
Started by sucahyo, November 26, 2008, 10:17:29 PM
sucahyo
Just an idea.
Sharp has been promoting plasmacluster device for a couple of years now. I happen to have one of them and found that it is effective to stop cold.
The plasmacluster work by generating balanced positively and negatively charge ion. This ion will kill virus or bacteria in the air.
We know that electrolysis will release some H+ and O- ion in the air. Would by doing electrolysis we also kill the virus, reduce smell, make air clean in our garage? If it is maybe it is a good idea to put a very small cell in our living room :).
Do plasmacluster work by electrolysis of water in the air? Would it make an effective electrolyzer?
It would be interesting to try to use plasmacluster for electrolysis. Or someone already try this?
sucahyo
Nevermind. I found explanation:
http://www.abc-varmepumpe.dk/uploadedImages/4361-aermec_ew_240_1.pdf
"PLASMACLUSTER ionising filter.
Plasmacluster is capable of reducing the level of pollutants, by decomposing the molecules that form them.
Using a series of electric shocks, "Plasmacluster" causes the water molecules present in the air to separate into positive and negative ions. These ions neutralise the gas pollutant molecules, forming products that are normally present in clean air.
The result is in the air: you can finally breath clean, odour-free ionised air."
It is electrolysis, maybe using high voltage (220V). But that also means our electrolysis cell is plasmacluster device :).
aussepom
Hi
          No it is not electrolysis, it more likely has an 'ioniser' inside. More like a sparking discharge this gives out ozone. They are using the 'plasmacluster' as a sales gimic.
aussepom
pese
Quote from: sucahyo on November 27, 2008, 12:32:37 AM
The ABC- device is an enery pump
the sharp an ionic cleaner
very good description here:
http://www.air-purifier-power.com/sharpplasmaclusterfppn60cxreview.html
Dr.Greenthumb
a plasma cutter kinda works like a arc welder. you have to make contact before it starts cutting and what ever metal it makes contact with its going to cut it. ive seen a controlled arc as a test hho and it eventually make a nice size implosion. ill try to find the video
