Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
AbbaRue
@Pirate88179
I'm following the Joule Thief thread too.
Sorry I was editing my post while you were placing yours.
@madddann
I think your right the MAHG looks like it may have lots of potential.
But it's a difficult unit to build too.
madddann
@Grumpy
"Maybe dielectrics can be polarized in different ways, or super-polarized by impulses."
- This does not sound new to me, a few times i heard of something like using dielectrics (plastic) as a conductor in combination with "radiant energy" and similar stuff like plastic as a core like in this old E. V. Gray videos:
http://www.youtube.com/watch?v=JQHUZITimUI
http://www.youtube.com/watch?v=YAThfMVKFGk
Dann
ramset
Wow
This is great!!
Refreshing !!
Thanks guy's
Thanks for the privilege to listen and learn
To hear ideas I would never have heard
My cup runneth over
Chet
Thanks Grandma
sparks
Quote from: Freezer on December 23, 2008, 01:37:19 PM
Awesome lecture by stan meyer, if you haven't seen it already.  This guy is/was brilliant..
http://www.youtube.com/watch?v=JyqQ-jXePO0&feature=channel_page
     Problem with Stan Meyer is he had a shitload of  "iron"  in the fire.  What is very obvious from his work is that voltage is where it is at.  And we don't need to have charge carriers to move it around.  Voltage makes mass do things and it doesn't have to be limited to popping electrons from one atom to the next.  I took the wire that goes to the crt in a yardsale pcmonitor and attached it to an iron coil.  Then extended the iron coil ends down through a block of pvc and then powered up the old monitor.  Instant ozone generator then these two flares coming off the ends of the wire started lifting a piece of paper towards them.  The ends of the wire were around 15kv over ground.  There was no obvious anode or cathode just these two little flares.
I stuck my paw in there after making sure I was insulated from Earth.  Damn little flares were sucking the heat right out of my hand 6" away from where the light dropped off.  I have never sensed cold coming from inside my hand.  Plenty of sensing cold coming into my hand but never being generated by my hand.   Now most of us exchange heat with the field in the infrared spectrum.  I got an idea that a plasma is a heat sucker innner.  Imagine being able to convert a wide spectrum of electromagnetic waves into electron acceleration.  I believe the same thing went on when I microwaved a paperclip with a couple of drops of water nearby.  Damn plasma started suckingup microwaves.  Hell space is filled with microwaves.
Cosmic background radiation.  I gotta get me a thermocouple and see how cold it gets near those little birkeland currents I had going.
   Modify:   Remember Grumpy said something about coils freezing the ground.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
ramset
Sparks
That was wild!!
Goose bumps wild!
You Got Sum Balls!!{A manly comment/compliment where I come from]
WHAT A GREAT TIME TO BE ALIVE!!
  Chet
Thanks Grandma
