Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
CrazyFox
@Sparks
Magnetic reconnect from the magnetosphere and the dynamo in the earth's mantel effects all electromagnetic and RF propagation. This is no secret during a Sun Spot flare (CME). A tuned or resonant system at the resonant frequency of the earth using a conducting magnetic loop should be able to pick off usable current using Tesla's formulas. A little large and large load cell (stacked capacitors) to store the energy. It is simply too cumbersome to construct and not reliable due to drift.
Atmosphere and oceans, thought to be a dielectric, are not. MHD of atmosphere and oceans in fact discharge huge amounts of current to earth ground (more correctly to lower potential). Artemus, the Swedish chemist and Noble Laureate, has much to say about MHD and the oceans as a charging system. The ocean Gyres with salt water produce huge currents.....but just try to show it on a meter. As fast as the current is created it is discharged leaving a small residual charge that can be measured. The earth system is too dynamic. Example: One could run a cable between poles of the earth and tap the potential .....ridiculous!
sparks
@CrazyFox
       Earth has been dealing with cme on a regular basis for a long time.  Nasa has a great video of a cme of large intensity hitting the Earth.  It was of the South Pole and showed up the perpectual plasmic whirlwhind  at the South pole.  I definitely believe there is an MHD current inside the Earth that is supported by the solar wind and creates the plasmasphere which collects the suns cme which runs the MHD .....   This structure as you stated determines the electromagnetic parameters of the cooking rock.  When a big cme hits Earth it pops power company transformers cause the impedance of the core is altered and the eddy currents go over the top and cook the primaries.  I can't imagine what would happen if Cern is pulsing away and a cme changes those coils impedance.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Quote from: TheBuzz on December 19, 2008, 04:09:56 PM
I doubt you are contradicting yourself, rather I just don't understand what you are saying.
I understand the Earth's atmosphere to be dielectric, the earth to be one plate and space to be the other. A bit like an inside out Leyden jar. Is this what you are saying?
You are being deliberately obtuse.
"Soil" is a polar dielectric not a conductor - look it up.
        -Frank Edwards
Grumpy
Quote from: TheBuzz on December 20, 2008, 03:04:38 AM
Well your user name certainly fits. No, I am not being deliberately obtuse, it is just something I have not studied.
Are you being a pointed object that causes me pain? Hartman doesn't want me to call people the "P" word anymore. ;-)
So anyway... is there a cavitation in the magnifier? Could Tesla have filled his dome with a gas such as hydrogen, helium  or nitrogen? I hear Tesla liked to play with tubes of high pressure nitrogen.
My name fits perfectly - that is why I use it - I am honest and true to myself.
There is cavitation at the spark gap.  Then, all of Hell break loose in the extra coil where the magnification occurs.  This is where the shockwave in the medium occurs - no electrons - no particles - mass of coil appears to facilitate converted but is not consumed.  Are you familiar with the work of Richard Quick and Richard Hull with Tesla Magnifiers and 2-coil Tesla Transformers?
The top terminal is a capacitor terminal - no gas - no cavitation here - it is coupled to the reciever(s) via a non-ionic field - no ionosphere involvment.  The very deep and expensive ground connection is coupled the same way  but through the earth and the earth can store a lot of energy.
        -Frank Edwards
Grumpy
Thanks Buzz - we are not different at all.
Pull all of the electrons out of something and it will come apart - at least in theory.
        -Frank Edwards
