Peter Sumaruck's "Zero Amp Tech" a Rotoverter?
Started by sterlinga, November 30, 2008, 03:33:44 AM
wattsup
The key here is what Sterling stated on post 1.
"output through his modified variable AC motor controller."
Modified how is the question.
ashtweth_nihilisti
Sterling. Before claiming to know what the RV is please understand what it is and read carefully. I just got sent this from konehead.
a quote by you:
""There are a number of discussion groups (e.g. pertaining to EV Gray
and Rotoverter) that have been pursuing this type of thing for
several years. When the motors run in resonance like this, they run
very efficiently in idle mode, but when a load is applied, they
exhibit normal efficiency"" -End
1) the VARS/resonance needs  to be extracted by a particular method we out line in the compilations, not series loaded, even some one who  tried for president once? should know that one.
2) We have shown by converting the RV in energy saving mode, (a drill) that by switching of the caps that it DOES give it more power on demand. (power factor correction)
Please understand that you have  NO - THAT IS NO knowledge of the RV's operation based on that statement,. Please correct it by reading the compilations and preforming the tests in the lab.
You can see our Drill test and explanation of the RV FOR DUMMIES  Later next year. Mean time , please read the compilations to understand the RV principle.
Thank you.
Ashtweth
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
pix
Hi all,
2HP el. motor running without load- doesn't mean it takes 2HP load.Induction el. motor without a load takes minimum current,2HP means it is capable to give such load-but then currents are much bigger.It is so simple.
On the video I would rather like to see on the clamp ammeter current IN, current OUT.
But the very BASIC error is to calculate output load as 7,5 HP when 3 el.motors with such name plate RATED power are running without load!
Regards,
pix
ashtweth_nihilisti
Test should of been
Battery->inverter-> black Box/Motor ----->5 induction motors driving
generators and putting power back to the battery, and running lights
(total power of the 5 gen sets worth of lights).
Demo should of run 24/hours.NON stop. At the end the battery is
measured with a hydro meter. Then he lets some on like Earl
independently validate it and produce the same results (non
disclosure). Simple.
Both announce test report.
Ash
wattsup
@ash
If this guy can show OU with amp/volts in versus amps/volts out, why would you then ask him to run a so so efficient generator. So what type of generator would you recommend? I'd rather want to know what the modification is to the AC control he is using and just check in and out.
Regarding generators, drive motors, etc., I just put up a post that discusses the pitfalls of using these for OU and I was even hoping that you would take a look and provide your comments on what I may have overlooked. It is located here.
http://www.overunity.com/index.php?topic=6116.msg141129#msg141129
