Pyramids sort virtual particles using casimir force
Started by froarty, December 05, 2008, 01:13:27 PM
froarty
calcium found in limestone blocks of coral or pyramid is a metal, even as microscopic powder it forms cavities equivalent to metal casimir plates, gas molecules trapped in these cavities see the reducton in virtual particles as a widening of the dimension of time in the cavity. this allows them to rotate into a normally impossible orientation that Dr Mills of Black Light Power has coined "hydrinos" (at least for hydrogen but any gas will do) these "twisted" molecules will simply untwist upon exiting the portion of the cavity meeting casimir geometry (<2nm) --HOWEVER-- if they form molecules while twisted the molecule remains twisted even after exiting the "plates" back into normal space - at this point they are surrounded by stessed virtual particles trying to push the atoms back into normal orientation but unable to overcome the covalent bond. the molecule is now oriented permanently away from normal space and is  larger than the 1 nuclei average width of the "present" as infered by the uncertainty principle (you can not know both the electrons momentum and location unless you are standing on the electron which is being moved smoothly from 1 position to another by displacement in the virtual particle stream) this tells us that electrons are already knee deep in time and infers the time width of the "present". We must agitate these trapped molecules into motion so they claw into the fabric of space-time and resist relative motion to the time stream up or down - sideways however I would not be surprised if a limestone block could be moved "1 bow shot" or 200 feet exactly according to legend - the block must be wedged up, then agitated either magnetically, electrically or sonicly and then remove the wedges and quickly scoot the block horizontally. (let me know if it works:_))                 http://www.byzipp.com/animation.htm
this theory also supports the shape of the pyramid as we sink upside down into the sea of time the virtual particles approach us like an air mass approaches the front of an aircraft -smaller VP go thru the nuclei mesh and larger go around to form a complex wake pattern interposing itself between the self repelling electrons and the protons they are trying to reach at their nuclei. If they must squeeze down and around geometrically expanding layers of "twisted" molecules and casimir stress fields while permeating the pyramid then the normally straight line path of the time stream can be thinned and widened as it permeates through more and more of these limestone casimir cavities. this even lends credability to the celestial observation tunnels as ancient gravitational engineers sought to utilize casimir lined channels
to leverage celesstial gravity agaist teresstrial
TechStuf
Quotethis even lends credability to the celestial observation tunnels as ancient gravitational engineers sought to leverage the delta in gravitational pressure theses microscopic fields could generate.
Sure, that's exactly what they did.  The slaves leveraged alot of things alright, but 'gravitational pressure deltas' weren't among them.
Perhaps Vimana powered by Baghdad batteries were also employed to get the job done on time and on spec, as well?
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
froarty
TechStuf
Oh, I'm not doubting the realities & possibilities of the Casimir force one bit.  Just the ancient gravitational engineers levaraging gravity pressure deltas, part.
Peace,
TS
TechStuf
This just in....BUGS BUILT PYRAMIDS......
http://www.youtube.com/watch?v=_ChsZUwqTeE
Although I'm sure there is a grain of truth to Grebennikov's account, too many incongruities make it very unlikely that he or our "distant" ancestors reduced such concepts or principles to practice at all.  Much less, in the ways described.
TS
