Magnetic wires as "Free Energy"
Started by PaulLowrance, December 07, 2008, 11:00:55 AM
resonanceman
Quote from: PaulLowrance on December 07, 2008, 11:00:55 AM
I'm interested in knowing what "free energy" designs use wires made of magnetic materials, such as iron, steel, or even PM's. I'm more interested in the designs where the "free energy" may come from the magnetic wires.
I think the TPU is one, right?  Any others?
Thanks,
PL
The  guy that created Coral Castle  was reported to have said  " I have made lots more electricity  with steal than I ever did  with copper. "   I believe that  the magnetic fields are attracted to iron . ...in theory this attraction  should increase the  energy level a little ........  If I am right about this ......the ideal  wire for OU motors and such might be a  soft iron  wire  heavily  plated with copper.( for lower  resistance .)
gary
sm0ky2
@ Res :  that there is exactly why some inductors are coiled around a ferrite core.
placing the core 'inside' the wire itself would be WAY more efficient!! great idea
@ PL,  those thermoelectric "CPU coolers" are almost perfectly reversable.
the power used to create a temperature difference is the same as the power produced when you sustain the same difference in temp on the two terminals.
in either case, you have to transport the heat energy away from the device.
   heating: you must take away the cold air from the cold side
   cooling: you must take the hot air from the hot side
generating with heat:  you must take the heat away from the cold side
generating with cold: you must take the cold away from the hot side.
as long s these variables are maintained properly
then Power in = Power out with 2 identicle devices, one used for consumption, the other production.
minus applicable losses
these same type of modules are used to make TEG generators, in a ring 3inches tall, 1.5 in thick and about as big around as a basket ball, they fit around the Exhaust Stack on 18-wheeler trucks, and produce about 1KW continuous electricity which is used to power some of the electronic systems in the truck
PaulLowrance
Quote from: resonancemanThe  guy that created Coral Castle  was reported to have said  " I have made lots more electricity  with steal than I ever did  with copper. "
Love it!  I have to use that quote somewhere at my website and forum!  Not only is the quote from a great mysterious man, but what he says is so true.
Quotethe ideal  wire for OU motors and such might be a  soft iron  wire  heavily  plated with copper.( for lower  resistance
According to my half-baked idea, I was thinking that best would be ultra thin layers of copper, iron, copper, iron, etc. Also, if the iron coercivity is too low, then there's not enough MCE energy. If the iron coercivity is high low, then it will take too long for thermal energy to reset the material during each cycle.
On top of that, finding the correct magnetic material is half the job. The magnetic material must be set just right; i.e., the iron cannot be fully degaussed or saturated.
PL
Grumpy
        -Frank Edwards
TechStuf
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
