coil size
Started by 4REAL, December 08, 2008, 01:05:05 PM
JustAnElectrician
Nice looking commutator!
Stick around 4real, your experience could be helpful.
I was looking at coil wire, and it seems to be cheaper now that copper is down. I hope to buy some before it goes sky high again.
Open Sourcerer Apprentice!
patmac
I agree with you, lenght is far more important in this system, I was thinking if current travel @ speed of light then with a very lenght conductor (20 - 30 miles) is possible short the input and this explain the very low consumption but high torque and excess output. For example:
Speed of Light = c = 186400 Miles per second aprox.
and traveling a distance of 30 Miles.
Then Speed of Light is slower here:
30 Miles / (186400 Miles/sec )  =  1.60e-4
THIS IS EQUAL TO 160 MICROSECONDS....
If you look on transistor datasheets actually MOSFTES or Bipolar transistor goes further.... including a good mechanical switching.
But if you put a coil with only 0.30 Miles for example :
0.30 / (186400 Miles/seconds) = 1.6 microseconds
is more adjusted harder short the travel.
u2btchr
It has been my experience that electrons flow on the outside of the coil of wire and not through it, thus it does not come close to the speed of light but much closer to the speed of sound. . . and this is in the 1200 ft / sec range. Thus there are many successful options to choose from in switching.
Correct me if my prior knowledge fails me as I am getting old .... :0   [nearly 40 years in education]
tchr
patmac
u2tchr
If you read Bearden he suggest electron travel very slowly:
http://www.cheniere.org/correspondence/030304.htm
But if you read the Newman theory's is fundamental to replicate a Newman machine then need use them in this thread in the page 51 picture says:
"Current moves at speed of light , but coil 16H2 is extremely long"
Then, speed of current is not same that seed of electrons.
kmarinas86
Quote from: patmac on December 25, 2009, 10:35:35 AM
u2tchr
The speed of a train may be 30 mph, but the propagation of force in a train is much faster than that.
