IST! NEO ZAP! TECK Breakthrough ....
Started by innovation_station, December 13, 2008, 03:23:34 PM
allcanadian
@also antlike
QuoteHow the fuck can you possibly know any of this?  Source, or I call bullshit.  95% of all quoted statistics are made up on the spot, like this one.
A selective photographic memory :) I can't tell you what the wife said yesterday or what we had for supper but if it concerns or relates to technology or science I can recall almost everything I have ever read. The source? this is the internet--google it, or believe what you want it makes little difference to me.
AC
This thread is a "laugh or cry" thread.  Way back last December the user Tosky gave everyone the low down on what is really going on with IST's demos.  Recently Farrah Day has been trying to hammer home the point about the futility of what is going on here.  IST is like the Energizer Bunny and keeps on posting his schtick.
The laptop power supply is charging up the coil so on the disconnects you get some pretty impressive sparking going on.  Don't forget it's around 40 volts DC and the coil is integrating voltage over time.  Plus 40 volts represents about 10 times the potentially available energy as compared to 12 volts.  The magnets are a smokescreen, it's just the clean shiny surface that makes good electrical contact that comes into play.
IST has been faithfully demonstrating the principle of conservation of energy in every single clip that he does.
sparks
    To get back to the neozap tech obviously the magnetic lines of force about a neo are very strong.  The magnetic dipole moments of the atomic lattice have been frozen in the mass of the magnet.  Any ions that may be produced by the carbon arc in the presence of a magnetic field will loop along the magnetic lines of force both out of phase and direction.  This could result in a charging of a capacitor as the ions travel a different path through the magnetic field produced by the neos.  Would the charge developed in the capacitor be in excess of the energy needed to ionize the air in the first place?  I often wondered how much charge there exists between hydrogen ions concentrated at the North Pole and the Ozone well now it's the chlorinated radicals down at the South Pole.  Below is a good read on how a neozap if fashioned properly and scientific investigations were made could be an energy collection system.  Converting atomic thermal energy into electrical energy.
               http://www.aspden.org/reports/Es8/Rep8.htm
This is a passage from the above which bears some relavance to selective ion acceleration resulting in excess charge seperation over simple imposition of voltage across a conducting field.
It is a curious fact of accepted physics that the interaction forces between two charges in motion are assumed not to have any dependence upon the mass of the particles transporting those charges. We use Newtonian mechanics to argue that momentum has to be conserved, momentum depending upon mass, but somehow eliminate mass from the electrodynamic problem. Why then should we be surprised to hear that when experiments are performed involving charge interactions between heavy particles and light particles, atomic or molecular ions and electrons, we encounter energy and momentum anomalies?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MrMag
MileHigh & FarrahDay,
you guys just wait. You will be eating your words when Willy takes his furnace motor and makes it self running and then hooks it up to his wind power switcher that is connected to BEMF cascade amp and then feeding his filsinger turbine air thruster engine that will be powering his water vortex generator. He will also use additional secondaries to feed the free energy vibrating neo zap spark gap which will run through his microwave magnet flux manipulation device using his crazy cap idea and the infamous MAMKC device. This in turn will run the high speed vibrating generator and filsinger squeeze tech pressurizer which will feed  the all in one motor generator. This output will run the pulsed electromagnetic homopolar generator, the filsinger pendulum generator, the IST V.A.HPG floating magnet generator plus the all in one turbine generator. These units will be started through the free electricity from crystals and of course using IST's npn/pnp circuit.
Laugh now, but just wait.......
It sounds like one hyper-positive feedback loop will be set up and everything will instantaneously vaporize in a Singularity flash of pure energy.
