IST! NEO ZAP! TECK Breakthrough ....
Started by innovation_station, December 13, 2008, 03:23:34 PM
triffid
I believe in Tesla even though Andrew A. Basiago may be full of crap.He said he was teleported to mars and says that mars has over one million humanoids living below the surface.To me these are wild claims but I will wait for his book to come out and see what others have to say about it.I saw the pictures of the rovers trail taken from space.Its hard for me to believe that mars surface is not all tracked up with footprints or other trails if living beings are on mars.Of course you have the martian winds but you also have protected areas(from the winds) where one could find tracks of some kind.I did want to mention his radio interview on coast to coast here on www.overunity.com
in spite of some of his more wild claims.triffid
Pirate88179
triffid:
Hey, that's cool.  As I said, that was just my opinion, everyone is entitled to theirs as well.  I try to keep an open mind about such things but I just didn't find him credible is all.  On the other hand, I believe everything we have learned about Tesla and I wish we knew the other stuff that is kept from public view.
triffid
Art is back on the show "coast to coastam" this next friday night.It would great to know what was taken from Tesla's apartment after he died.triffid
Pirate88179
triffid:
I love it when Art pops in from time to time.  Thanks for the heads up.  I actually called in and spoke to Art about 6 years ago or so.  He is a great guy in my opinion.
Thanks again,
gauschor
So I tried to replicate the neozap, but was not successful I think. I admit I used parts that were not exactly the same:
Instead of a MOT (which has specifications like 120V input, 2000 Volt output) I only used a common transformer, which I had at home, with specs as follows: 10V input 220 V output - however the "proportions" seemed to be approximate. I had neodym magnets, 20 pieces, each 3cm long - which too is different compared to the flat ones, IST used).
My device was powered by a simple 9V battery. I used the 10V primary side for input and the secondary side remained open.
Result: babysparks :-[ and a smell of burned material in the air after a while.
Ok, anyways, what I have seen on the voltmeter is, that the primary transformer coil creates a big EMF when closing the contacts, and another big impulse when opening the contacts. This is commonly known though. The voltage on the primary coil however showed peaks of 1500V+. I am not sure how I should interprete this, maybe it's the collapsing impulse from the "unused" secondary coil which causes a final impulse in the primary?
If I removed all magnets I still got the babysparks. I think the sparks were a little bit better with at least 1 single magnet, but I believe this was caused by the very smooth conducting surface of the magnet and not by an amplification effect.
Afterwards I tried the same circuit powered by a Wimshurst device, which however resulted in nothing. I wonder if there is a minimum power input required to get decent results, for IST used a laptop power supply which is much greater with its 19V@4A...
