Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
Quote from: innovation_station on July 20, 2009, 12:00:14 PM
great work jesus ..
but you have some huge neos in there do you think there is an induction generation thing takeing place cuz the neos ... ?
that may be aiding the effect ?
ist
Thank you @ist
The clear one is a neon, the red one is a camera red led.
I left the neon there just in case, it was from the original bedini circuit.
The red led is to know if it is working, or producing electricity and at the same time it is the diode from ground to base of a bedini circuit.
Jesus
Edit:::
I think that are the neo magnets you are talking about and not the neons.
Those neos are the only ones that trigger the current on the coil to trigger the transistor.
If I used a smaller one the transistor did not trigger and I had to use a reed switch to trigger it.
After I put those the trigger problem was solved instantly.
By the way those were a gift from my brother Franky.
Jesus
nievesoliveras
Quote from: resonanceman on July 20, 2009, 12:21:16 PM
Jesus
Great  work      :)
I have  connection  problems too .
I see  you are  posting  quite a few  pictures
My connection is  bad enough that it often takes me  2 or 3 tries  to  load  a page here.
Posting   a reply  with  a  picture  pretty much  impossible  if I  do it all at once .
I have found that it works pretty  good to  post the reply without  the  picture .......then  go back and use  the modify  button to put  the pictures  in  one at a time .
I hope this helps   save  you a little time
gary
Thank you @resonanceman !
The problem is that after I make a post with photo or without photo the whole page turns dark gray and it does not respond to any button I press.
It just keeps moving the earth globe three or four turns each time I press a button, but it does nothing.
I have to close the window and start to enter again.
Thanks to god I finish posting the information.
Jesus
nievesoliveras
Quote from: jeanna on July 20, 2009, 02:11:27 PM
Great work, Jesus!
And thank you for the step by step. It makes this so much easier.
jeanna
(I have been  clearing the history from my browser. This gives the chitika nothing to upload from my browser and it seems to make the pages load very fast. I sometimes clear the history more than once a day.)
Also, did you change the appearance yet?
left frame,
bottom,
below people online is theme selector.
Change it to the pale blue plain.
No OU flash pictures to load each page. = much faster.
jeanna
Thank you @jeanna !
I will do that and see how it behaves.
Jesus
Cap-Z-ro
Jesus...I had a gummy pc once and had the same probs losing posts from restarts.
Try opening up a 'word processor' program
and type it there, save it, copy it and paste it in the forum window.
If you lose it, you still have it saved in 'word'.
It was very considerate of you to simplify the process for all the novice's among the readers...who may even become inspired to enhance the circuit.
When that happens, everybody wins.
It will be interesting to see if down the road the motor can be made to carry a load.
Regards...
nievesoliveras
Quote from: Cap-Z-ro on July 20, 2009, 08:55:16 PM
Regards...
What I began to do is to run notepad and type what I want to say in it then when I am prepared to post, I then go to the forum.  so you had the same idea but with word.
About the motor, I know that it will be improved by someone and it will come back to me.
There is a saying, that you reap what you sow.
Jesus
