Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
@all
Remember that it will charge the battery some points below its natural voltage, because it is used at the same time.
Example if the battery without the joule thief load was 1.03V it will be working some points below that initial voltage and charged at the same time.
When you take it off it will be back to its original voltage or better.
After you verify this, then we will need the assistance of the @pirate topic crew to use the system to light something with the same amount of energy used by the circuit without an added load.
Jesus
WilbyInebriated
just an update.
i'm still @ 1.24V
nievesoliveras
Quote from: WilbyInebriated on May 28, 2009, 05:38:52 PM
just an update.
i'm still @ 1.24V
Check if taking out the charging diodes an LED works on the circuit and after put everithing back as it was.
If the circuit is working properly, yours is performing better than mine.
You can leave it the whole night working and in the morning the battery will be the same voltage as the last measurement you did today.
Jesus
WilbyInebriated
Quote from: nievesoliveras on May 28, 2009, 06:42:58 PM
Jesus
just tested a led across the collector and emitter. good light, all is working. removed led and will update you in the morn.
shubhamforme
checked out everything and it dosent work.... this circuit does not work my battery still at .4v from 1.3v within 5 hrs
Quote from: WilbyInebriated on May 28, 2009, 09:47:17 PM
