Natures Perpetual Wheel
Started by FreeEnergy, December 15, 2005, 05:23:25 AM
Tink
Daniel are you okay?
Who are you working for?
NSA?
Synergy is the key to free energy.
lltfdaniel1
i work for nobody,
anyways it should not take long to figure out how to break ather waves.
im going use Nails (in a row of 10 x 10 ) with paper clips (on the tops hooked) and see what happens,
hey , you can see the 'invisible energy' when you close your eyes, its colour is blue and it has nothing to do with your human eye sight.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
ooandioo
You are right, i see it - but wait, isn't it sunlight going through my pulsing venes?
mh
lltfdaniel1
its em energy , can you see that?
i think ive got an idea of a way to replicate the telsa vaccum electron Tube.
since no where on the internet , (did a quick search) does it ever Clearly explain how to get one of these running.
But SINCE YOU CAN PUT A WIRE 2000-4000 FEET IN THE AIR AND YOU GET Enough power - volts because it gets closer to the magnetic power of the earth,
and since the volts down here NEED Boosting, like a radio Booster,
http://www.keelynet.com/interact/arc_1_99-4_99/00000272.htm
Tesla found that the energy peaks at 12 Hz, 500 Khz and their =
harmonics. That is why I mentioned 12 Hz. I had once thought that Tesla =
used the vacuum tubes because he was using aether, but after looking at =
some of his other writtings and experiments with this electricity, it =
seems as though he built the box to increase the current of the =
electricity. I'm sure that this is possible and had I a better =
understanding of vacuum tube technology I would try to explain this in =
more detail. The reason I believe that his box was in fact built to =
amplify the current of the electricity is because Tesla had already =
conducted similar experiments as Jerry Gallimore had and had the same =
trouble that Jerry Gallimore had with a weak current. It is therefore =
only logical to conclude that Tesla used this same atmospheric =
electricity. This is not only indicated and supported by Tesla's notes =
and diagrams, but his methods resemble the later experiments of others =
like Jerry Gallimore to such a degree that it is silly to conclude that =
they were not using the same kind of electricity and obtaining it from =
the same source. All Tesla needed after tunning in the peak voltage =
frequency was to increase, or amplify the current by some means. That is =
why I believe that Tesla built the converter box not to convert or draw =
power from the aether, but to amplify the current of the electricity =
that he was recieving from the atmosphere. =20
hey why not try your cloth hanger that would be a pretty good ariel to test to see if you get any Volts which would be likely Anyways.
So with this all you need is a rod and a tube to accelerate and ampify the electric signal thus geting More volts(like a radio, even see patents where they get electric from a radio??????????), which is easy to see aint it?
with a bit of fiddleing about we could get a telsa electron amplifyer, because you do get volts in the air , and this Amplifys THOSE VOLTS.
as we know ( and 4 billion of the population dont.)
it just needs to figure out the circuit , but AC ELECTRIC Is flexible .
why not stick a rod in a vaccum tube and place 2 wires(to the ROD or 1 to the tube and 1 to the rod, or completely to the vaccum tube) and then connect it to a Bulb.
IF THE BULB DONT MELT .
lltfdaniel1
i think the only reason why he used resistor is because the circuit would of Fryed, with all those Ether volts..
or why would of he used it?
