Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
Goat
@ All
I am starting this thread with Gadgetmall's permission in order to expose his feedback to source Bedini circuit to everyone that may have missed it in the other threads.
I find his approach quite amazing and unique in that he is using a separate coil to gather and feedback energy to the source!
Here are his videos:
http://www.youtube.com/watch?v=LczzeeyfFoA  also http://www.youtube.com/watch?v=JRnYQvYEwkM
There is some information that is lacking and replicating his setup will take some information gathering but here is his latest circuit and component values.
@ Stefan - Would it be possible to give Gadgetmall or my account permission to post the latest information gathered at the beginning of this thread so that people will not have to go through all the posts to find the relevant information?
Regards,
Paul Gauthier
Goat
@ Gadgetmall
No Rush on this request, whenever you get a chance  :)
I'm trying to put together a Materials and build list to try to replicate your setup.  What I'm looking for are questions regarding the following components:
Welding Rods - Type ?
Length of Welding Rods ?
PVC pipe for primary coil- ID/OD (I think you mentioned 1/4" ID in your video) ?
Length of PVC pipe ?
Primary Coil Wires - 2 wires as per circuit, CW or CCW?
Primary Coil End caps - What type of plastic and size?
High Voltage Diode going to Primary from capacitor - Type & Values?
Primary Coil Winding - There's a discrepancy on your video regarding the gauge size of the wires used, is the size in the above schematic the latest and correct for the wire size?
Secondary Coil Winding (Piggy back coil) - ID/OD X Height?
That's it for now, I'll probably ask you more questions later  :P
Regards,
Paul
Goat
@ Gadgetmall
Again, no Rush on this next set of questions, I know it's a lot to ask but whenever you get a chance.
Amendment 1:
1.  Welding Rods - Type ?
2.  Length of Welding Rods ?
3.  PVC pipe for primary coil- ID/OD (I think you mentioned 1/4" ID in your video) ?
4.  Length of PVC pipe ?
5.  Primary Coil Wires - 2 wires as per circuit, CW or CCW?
6.  Primary Coil End caps - What type of plastic and size?
7.  High Voltage Diode going to Primary from capacitor - Type & Values?
8.  Primary Coil Winding - There's a discrepancy on your video regarding the gauge size of the wires used, is the size in the above schematic the latest and correct wire size?
9.  Secondary Coil Winding (Piggy back coil) - ID/OD X Height?
10.  Weight of Primary coil?
11.  Weight of Secondary coil (Piggy back coil)?
12.  Base of Primary coil, materials used?
13.  Size and Strength of Neo magnets used on HDD motor and Platter plates?
14.  Neo magnets facing N or S at the coil core?
Thanks again for making your videos available for all to see, you certainly got my attention  ;)
Regards,
Paul
gadgetmall
@GOAT
Paul, here is the latest Cleaned up Schemitic and i will try to find the time to fill in the blanks .I am a Single daddy with a 7 year old girl and we have a Birthday party this weekend and lots of preperations to make .   Re: Fusionchip's Bedini Feedback to Source!!!
« Reply #2 on: January 12, 2009, 12:00:08 AM » Quote
@ Gadgetmall
Amendment 1:
1.  Welding Rods - Type ? i will try and find out by a welder . they were junk yard picks-rusty
2.  Length of Welding Rods ?will measure
3.  PVC pipe for primary coil- ID/OD (I think you mentioned 1/4" ID in your video) ? 1/4 sch 20
4.  Length of PVC pipe ? will measure later
5.  Primary Coil Wires - 2 wires as per circuit, CW or CCW? CCW
6.  Primary Coil End caps - What type of plastic and size?TEFLON cut in  2 inch DIA circles
7.  High Voltage Diode going to Primary from capacitor - Type & Values?RCA SK3606
8.  Primary Coil Winding - There's a discrepancy on your video regarding the gauge size of the wires used, is the size in the above schematic the latest and correct wire size? correct in new schemitic .Verified 16 and 20
9.  Secondary Coil Winding (Piggy back coil) - ID/OD X Height?will measure later
10.  Weight of Primary coil?..minus the core  5 1/2 pounds
11.  Weight of Secondary coil (Piggy back coil)?a tiny bit over 1 pound .i have a postal scale no grams
12.  Base of Primary coil, materials used? Bakalite i think . it was the mercury relay base .looks like it has some fiber in it ? kind of heavy but looks like plastic too ?? I dont know but its from the 60's
13.  Size and Strength of Neo magnets used on HDD motor and Platter plates?  ebay Cylinder 1x1/4 n48
14.  Neo magnets facing N or S at the coil core? N
15. i would like to add that the piggyback coil might be wound cw or ccw . there is some black stuff sealing it and the outside layer is like black cloth or fabric . i peaked at it and got the wire size but no real indication of how it is wound so ???? Varable. I think the aire core hole has somthing to do with the properties . also i dont know if its copper or aluminum or what because it terminates in a sheathing with connectors crimped on it . Couild be iron copper aluminium gold silver . i dont know but i know its worth a lot to me .No its not for sale unless you got a million dollars ;D
Best regards guys . i will return
Al AKA fusionchip AKA 4Chirstonly1 AKA GADGETMALL  :-X
Goat
@ Gadgetmall
Thanks for the PM, lot's of good information, I appreciate your help and your time very much!
Please point out mistakes if any.
Amendment 2:
(Undetermined - local surplus scrap yard -  number of rods and there exact length TBD)
(Length TBD with 2" sticking out past length of 1/4 inch schedule20 pipe)
3.  PVC pipe for primary coil- ID/OD?
(1/4 inch schedule20 pipe)
(2" less than the length of welding rods)
(Wound counterclockwise starting from the back of the coil)
(Teflon cutting board cut to 2 inch circles)
(RCA SK3606)
8.  Primary Coil Winding - correct wire size?
(500 feet is correct the size is correct in schematic 16/20 )
(5000 ft number 32 clockwise)
(Bakelite)
13. Shield?
(Shield made of steel and ferrite)
14.  Size and Strength of Neo magnets used on HDD motor and Platter plates?
(Ebay Cylinder 1x1/4 n48)
15.  Neo magnets facing N or S at the coil core?
(North)
Regards,
Paul
