Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
plengo
@hartiberlin
thank you Stefan for the tips. I did try in my "1000 variations" of this circuit to use the n5408 diode instead of the n4007 and surprisingly enough I also thought as you BUT it did not work at all. Do you see my 5 diodes in series they are noway even close to the characteristics of the SK3606 that I could find on the net. My conclusion (most probably wrong and non-expert) is that radiant likes low frequency and resistance better than positive electricity, therefore the 5 diodes works better in their "resistance" level at a whole for the radiant (taking in consideration that radiant does not flow inline or even in the same direction, necessarily,  of the regular electricity :).
The 4007 diode is only good to let the BEMF flow but it is horrible for the radiant (no wonder Bedini puts that one on the SSG monopole for everyone, off course limiting the COP that people can get in purpose - well stated in their forum). In other words I agree with you BUT my testing shows the opposite.
The only place I used a ultra-fast diode the mru1100 was in place of the new capacitor cross the transistor emittor/collector which worked very, very well, BUT the capacitor still gave me the best results.
As of now that I type I still have a FAN running with the voltage on the battery being the same BUT now I have a new problem... my fan is accelerating and therefore increasing the current consumption which WILL KILL the system so I have to watch it closely to avoid that.
@ALL,
so until now I do have a running system with no visible measurable voltage decrease anywhere. I do have an excess energy manifesting itself in the FAN speed and that IS A PROBLEM. Let me explain better. I fell to mention before that to get this thing running correctly one can not just spin the fan and let the system run, one MUST spin the fan with the minimum consumption of current as possible ( and this is not only because the  the battery being able to charge at that rate only - I will explain that later ) and least spinning as possible. If one gets the fan to speed up to, lets say above 500 rpm, it will simply waiste too much energy and not generate the radiant spikes, one will find that the system is now in the best speed mode but not necesserely in the best re-generation mode. Currently my system was spinning at 266rpm and now accellerated to 277rpm.
The reason of the minimum current consumption is not only because the battery, being not conditoned well, will not re-generation enough energy to recuperate the used energy, it is MOSTLY because positive electricity will EAT UP all the radiant energy. Radiant comes first and current comes right after. Tesla stated that, Bedini and many others.
So, having this system running with too much current will at some point just kill all the possibility of any radiant energy appearing and therefore having the COP we all want.
Please dont kill me for this statement of mine now: I think that for every 12 volts 10ma one creates, one can get 100 to 200 volts scoped measure radiant energy, anything above that power ratio will only deplete or kill the potential radiant energy visible to use. That ratio will be also proportinal to speed or frequency. In other words, faster more voltage and current one can use to manufacture radiant, slower, much slower we get at that 12v by 10ma stated before. Am I craizy????!!!!
We need help here with experimenteers!!!
Fausto.
hartiberlin
Hi Fausto,
I see, strange effects.
Can you please show a picture, which shows exactly the fan and how you modified
the windings, so that it looks now like a transformer ?
Maybe you can put a small light bulb in series with some
fan windings, so if the current raises, then the bulb will conduct
less as it heats up the filament, so the bulb resistance increases ?
Would be a simple control mechanism..
Many thanks in advance.
Regards, Stefan.
plengo
@hartiberlin
tomorrow morning I will take pictures of a brand new FAN being modified as you asked, after all I bought 3 exactly for that.  This other fan is identical to the one running. I can not open the one running because once you open it you will break it and you must glue it together and this is my only running prototype, but it was in my plans anyway to replicate this 3 times and from the second time on have plenty of pictures, movies and descriptions of the process.
BTW, fan still spinning and I got a little run away once I bypassed the amp meter. Fan accelerated to 300rpm and current increase ( I think, because the amp meter is off ), voltage on the battery dropped instantaneously 0.01v. I get desperate (this is my baby :) ), I removed the bypass, put the amp meter back and rpm dropped to 266-270rpm and voltage instantaneously was raised back 0.01v, amazing.
For a moment I thought I lost my setup context and I would have to start all over again. You see, I am trying to keep this one context (setup speed, current consumption, electronic parts, wirering and so forth unchanged so that only one variable is in place, just as science requests).
I hope everyone understand that I am being honest about this setup and if it FAILS I will also be honest and let everyone knows what the outcome is, going up or down. Right now, I am very happy that my battery after over 54hours has not dropped voltage (except for that incident above but came back to where it was) and this is impressive for me at least the knows that battery very well.
Cross fingers guys.
Fausto.
gadgetmall
Quote from: plengo on February 16, 2009, 02:12:35 AM
@hartiberlin
Cross fingers guys.
Fausto.
Fasto here is the sound your requested of My powersupplybedini . It is a wav . About Halfway i take the output lead off then put it back on .. then at the end i slightly move the pot .
I might add that No one expects you to lie on my behalf . I Don't know you  . I would be skeptical too . However i have been in this free energy Projects  way before 1989 . You don't believe me . Have a look at the bottom of My Screen with the dipalma quote . there you will see me begging for some clicks on My web site ADS. on there is some correspondences from a friend of mine . Barbara Hickcox and her patent . i have access to the full patent and plans that sell for $100,000.00 dollars . i will never give them away for free . .Nor  will not sell them . and she was in this when Howard Hughes was alive . You have been here on this forum longer than me . I know its Strange that all of the sudden someone pops up with all these selfrunners and claims of overunity but its time SOMEBODY Steps up to the Plate . there are way more inventors out there with Much better things than i have . I am Concentrating on Small Stuff with the Lowest Possible input Current Circuits and to produce Very Long Run Times and high outputs  . I now have several Circuits of which are public . If you get them to work for you great if not Don't you Dare Insinuate i am Lying to you . I am Sharing My results . I really don't care if you get it or not . Doesn't Matter . I got it that's what Counts to me  :) I have several Degrees but I am Not Dr. Stiffler . I understand he is a Pain in the ass and wants to delete every post that offends him in some way . I think he is a SNOT . PLUS his experiments prove nothing that i have seen except you can take a Sig generator and feed a signal; in something and get some power out of it . Whoopee . I can do that with My pulse Generator . input a  .5 Volt pulse at a Set frequency into any LC circuit and you will get more out than in .Cold Electricity we got fugoi. No we Cant light a incandescent lamp under water becaus ewe dont have a 1000 dollar special signal generator . I don't see what the fuss is about .And yea He uses unusual parts that contain Barium and Radioactive Ferrite and has 10's of thousands of dollars of test equipment  and all his Fancy Math . Makes it look real good .If its Something Worth Having Be open about it and Share it offer to sell it or what ever . Well It make me look Like the Pig Farmer that invented the time Machine :)
So you tell it like you see it Fasto  . I gave all i can give for free . Take it or Leave . Its Like God in a way Some will receive his Glory  some won't (Bad example i know but its true ). Well i hope your see what i see thats all . I already see that the fans are different resistance . So one has more windings that the other i guess production was not perfect that why they are so cheap i guess? Lucky for me .the way i see it unity is easy as pie . I don't know why others dont see it . I have a lot of time on my hands now i guess and while Baby is in School every day i piddle and put a part here and there and WALA ! I don't Necessarily go by standard Circuit Building . I think outside the box . Maybe its a gift i got after My Anurisium .Maybe its because i am not afraid to Die like all the other Free Energy Inventors that got Scared away or Killed . I just know It's time someone DID SOMETHING Worth a Flip .
regards
Al
plengo
@gadgetmall,
thank you Al, I really appreciate your openness and willing to share your inventions. I never doubt you not even when I only saw your videos in youtube, I guess it pays to thrust people first.
The sound is SOOOOOooo helpfull, I can in my first analysis see that you are definitely having many more pulses per rotation than I have and is also spinning sligthly slower than mine.  As you said, the resistance of your coil might be different. Hopefully my next fan will be better.
My system is running good. It did drop today 0.01v but, as I said before, turn off the system, let it rest for 5 minutes and back to where it was and running again. I think my system is still not well tuned as yours. I will get there.
Fausto.
