gadgetmall
H@all . ok im still trying to improve this circuit to obtain real use of my machine with inverters . I have experimented with a reed switch in series with the primary power coil which slowed down the rotor and produced more power . It was an experiment and i will probably hard wire it in later . Also i have been testing a second Trigger coil as pictured and i think i like this the best . it spins much faster and i will be running this setup to determine if it sucking power to fast and i lose the ove unity i have with one trigger . i will run this setup for a bout a week and let yall know if this is an improvement or not .. the extra trigger is in series with the primary trigger . also in the second photo i have added a second transistor in parallel with the first one hoping to improve the draw of voltage on my primary to attempt another try at running off the caps alone . The first attempt left me with a pile of bad 2n3055's as the voltage coming off the piggy back coil is too high for the 2n3055 and Blows them instantly . Maybe two in parallel will increase the capacity to 200 volts and not kill the circuit . i will let you know after a week of running the 2nd trigger . One note comes to mind . I don't think the setup is critical other than the fact that the coil configuration of any bedini could be changed with the core protruding out the back of the coil . the reason i am telling you this is if you have a bedini already make a new coil like mine and use an experimental piggyback on it and see if you get the results i do . the more windings on the primary the less current it will draw . Mine can run on as low as 6 ma's . and as high as 500 ma's . I built a bedini for my brother not like my design except we left the core open and i put my piggyback coil on his machine . It (primary)remained the same running voltage for 6 hours thus proving that the design is not to critical . i think with a little rewinding of the coil i made for him it would self run too . the only think is he tried to wind a coil like mine but wound it on a longer pvc sticking out the back and it did not produce the voltage or current My Magic coil does . BUT he did not use tiny wire . i think it might have been 26 and i think he wound it counterclockwise the same as the primary . he gave up cause it took days to unwind the wire from a BIG toroid for his piggyback and left it like that . I guess when we get the time to undo it and rewind it the other way with the same wire we would get better results .. Ok go for it !!!!!
gadgetmall
@GOAT
        i stopped the test to take a picture of My piggy coil . here it is . i will try and find ruler and post it later in the week the dimensions ..
Goat
@ gadgetmall
Thanks for posting the picture of the piggyback coil.
I have a brother in law that works in industrial electric circuits, I will forward him all the information you gather and I'll try to find out if he's ever come across an old Mercury solenoid with a coil like this in his line of work.  He possibly might know of other units that use a similar coil.
Edit:  Was the solenoid switch that you had look something like this (see picture below) and did it have any markings on it that you would still have access to?
http://www.mercuryrelays.com/shoppingcart/agora.cgi?&product=35amp
Again sorry for all the questions and please do not pressure yourself to find the answers.
Thanks again,
Paul
gadgetmall
This Coil is the key along with My Geometry of the Master core Material Sticking out the back . I think rather than replicate the whole thing Build a Bedini with a large gauge twisted pair  CCW as a Normal Bedini is . and leave the core open air core then experiment with different rods, or i thought of using bailing wire cut up in bunches might have even better results than i have now . My core is not glued or coated and can be removed easily and i will try the bailing /electric fence wire and see if the results i have improve more . My goal now that i have it recharging with over unity is to create More power for bigger battery's and run stuff from an inverter off the switched primary to secondary . I don't think this will run off capacitors as they just don't have the properties of a real battery and this is going to need a real battery for overunity effect i get . I don't know why a battery works and a cap don't but the battery is another key to self runner producing usable power ..  I would concentrate on the piggyback coil replication first then if you already have an existing Bedini coil replace the core with materials i have suggested protruding from the back and i bet you will see Good if not overunity results . Also the piggyback coil produces over 70 volts on the ac scale without any bridge or cap ,Just open . Then one my Brother made did not produce more than 11 volts ac ????
gadgetmall
The Gold Disks i use are from one of the first hards drives made by Segate and i understand  the platters are made with platinum, gold and palladium along with Aluminum . But this don't matter !! Because it self charges in oscillation mode even stronger sooo i would not worry about the material of the rotor . its the coils !!! and the way they run with minimum current draw . that is another key . get your bedini running at 10ma or less either turning the rotor or solid state ! That is all i can do for now . i'll come back later in the week with some test results and coil measurements . Kirk out !
