Black Box.
Started by lltfdaniel1, December 19, 2005, 10:53:03 PM
lltfdaniel1
GIVE Glory to URIEL (THE ARCH-ANGEL)Please BECAUSE He Conducts THIS ENERGY.
I Don't have any knowledge on the 'Vaccum tube' or how Good it would Be as an Electron 'Collector'
but Telsa 'USED' 'TWO' 'RODS' ONE FOR 'NEGATIVE' ONE FOR ' POSITIVE'.
AND THEN That Energy electrons went into the Box and which was Collecting 'Electrons' and the 'Electrons' go into the ' Vaccum tube' and the 'Vaccum tube' circuit was Connected to the ' Motor'.
i hope that gives you a 'better insight'.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
telsa's ''FLAME OF Fire(energy), in a tube.
it doesn't work like a telsa pump, rather the rod gets this energy near the black box, ..
and God has given me a vison to how it works. (looks.. to)
it seems that this energy,
its like a deep ish (bright) yellow colour,brownish.
in the vaccum tubes (?)
and these vaccum tubes was really powered of this strange type of electirc power
and in the vaccum tubes, this light can be stepped up and thus give more power , (like) a laser beam actually but in a vaccum tube.
and this gas enters thru the black Boxs rods and the gas travels to the vaccum tubes and it then Fusions and produces electric. (the dual circuit must be connected like as shown other wise the electron flow would be unstable).
now all i gota do is figure out , what type of Light energy is this.
then i can understand..
and why would he used... a radio active material in a rod for?
what kind of Ions was he collecting?
and THIS light Produced electric.
WHEN IT Hit the top of the vaccum tube(metal).
and then it gets restarted back into the bottom of the vaccum tube and goes up and hits the top which gives it electric power(after the process in the vaccum tube).
and when it did it produced a electrical Radiation. (God has said this energy is the same type as that of the Joe cell ....but this process in the vaccum tube acts differently)
because it turns invisible ather energy to like a liquid voltage energy.
(instead of A Hydrogen type , like that of the Joe cell,)
which then went into the wire. (the light radiation, which was put into the wire, from the top of the vaccum tube) is then drawed to the motor and powers it.
its something simular to the joe cell...
but instead of useing acid like that of in a joe cell, the catalysous of this energy is some 'Radio active element'. and This Mysterous energy is the same as of the Joe cell, but with this its Ather,not water ,and it turns to a some ' pressure , liquid voltage
which then seems to 'Seed' it self into the Vaccum Tube, instantly.
and the radioactive (catalyser) rod is what 'Feeds the seed'.
its like some kind of a Liquid Voltage Nuclar Process, but in a vaccum tube which you can change the power by Adjusting it ? O_o? (like is if it was a light)
speaking of Joe cells, the vaccum tube and the joe cell like very simular .
and then in the vaccum tube , this energy acts like a catalysor to its self and turns to electric (somewhat like a fusion, in a vaccum tube).
ts like some kind of Ather GAS(due to the radio active rod which spilts the surround athers).
this Ather gas travels to the black box's 2 rods and then travels to the vaccum tubes and then it reacts with its self and produces electric (and if you could see this ather it would be like a Line thru a Mist whilst traveling to the 2 rods of the black box.)(due to No Air, it Reacts with it self)
like when hydrogen reforms in a fuel cell, but this .. with the vaccum tube,thus Produceing a Radiation of (free flow)AC ELECTRIC,
and to control the power, the turner on the vaccum tube controls the pressure and then less reaction thus less power.
this ather gas(which is the black box's fuel) also comes off the Joe cell as well,when its Alive, with its Sludge. so build a black box (if you can from its avaible diagrams, and see what happens..whens its near the joe cell)
(if you want a Generator)
BE CAREFUL If you do test this, and don't test it when its in your hands -_- its alot of volts.
(God has told me what to write, in this, i have no clue to how telsa vaccume power whatever works, it seems its this Mysterious ATHER Gas, which can be produced from the joe cell as well,or put a vaccum tube near it if you wish,but be very careful..)
if this works , as stats aboved i would shit my self.
i hope thats explained enough...and i hope it works..because who knows what the joe cell is capable of (who knows, everybody who build one, wonders that)
and all that power near a joe cell would be crazy (even with a 12 volt battery is enough )
i wouldnt dare what the Dangerous results would be.
i think telsa used the battery for the rod , so that it could spilt of this ather gas which produced far more electric in the generator prehaps, who knows his secret died with him, due to people ridiculeing him.
its worth a shot isnt it?
btw this ather gas isnt harmful,or dangerous, all of this Reaction happens safely in a tube.
http://www.keelynet.com/energy/teslafe2.htm
(it talks about pressures and athers, don't you think it could JUST Maybe have a Possible connection with the mysterious effect with the joe cell to?)
lltfdaniel1
well im going to leave that up there,
i hope it could be made of any sucess.
lltfdaniel1
you know not long after i posted this , i had an artifical sound in my head, guess what it said?
SHUT UP.
lltfdaniel1
and i knew it was one of there agents on their machines ;-).
so whatever your reading (the last post)
ITS On the right LINES (HOPEFULLY You could Build of that to make a REPLICATION)., but even in more detail to help you replicate and the idea will zoom around the net like the joe cell did.
the Lord Guardian of Divity shows me about the machine and then i typed it down ,
like a flameing laser liquid of voltage (has a connection with the joe cell)
AND If i didnt knew about this famous joe cell i wouldnt be able to have knew how the telsa 'Flameing' ''nuke'' rod, which is what most of you are calling it ,
being honest i had no clue to what i was writing , i was only descrinbing what God Showed me, and i know its from God, now what i typed in detail actually (supriseing to me)
makes more sence now.
when i read about telsa discription.
