Free Windows XP Backup solution with DriveImage XML and UBCD4Win XP LiveCD.
Started by hartiberlin, January 14, 2009, 07:26:45 PM
hartiberlin
Hi All,
the last days I fought with getting a very good backup solution to work
for Windows XP.
The free program I used was DriveImage XML
http://www.runtime.org/driveimage-xml.htm
with which you can backup whole partitions directly from within Windows
also to external USB drives or other drives.
You can also backup drive C: where the Windows XP installation is normally on.
The only problem was the Restore problem.
DriveImage XML does not come with any BootCD for this reason,
so if your partition C: crashes, where your
Windows XP installation was located,
you needed to hook off first your HD to another PC and restore there
the partition C: via a working Windows XP installation.
But now I have found a much better solution:
Booting Windows XP from a LiveCD or from a Live USB Stick.
This can be done by using the free program
Ultimate Boot CD 4 Win Version 3.22
http://www.ubcd4win.com/downloads.htm
The problem then was, that this is no ready to burn BootCD
due to the problem with the Microsoft WindowsXP licenses...
So this program uses your own Windows XP CD to
create a bootable Windows XP LiveCD with many
tools program on there and also with
DriveImage XML.
So you can boot then this WinXP LiveCD or the WinXP USB stick and run DriveImage XML
from the CD or from the USB stick and Restore the partion-backup  directly to
your build in harddisk.
So far so nice, if my Windows XP CD would have worked with Ultimate Boot CD 4 Win Version 3.22....
It did not work and after a few tests I have found a downloadable free Windows Server 2003 R2 trial
version, which also works with Ultimate Boot CD 4 Win Version 3.22.
Here is the Windows Server 2003 R2 trial
version:
http://www.microsoft.com/windowsserver2003/r2/trial/installinstruct.mspx
and then take the first Image file:
first English ISO image file file name: X13-05665.img
http://download.microsoft.com/download/E/5/C/E5C2CA69-28C9-492A-8F57-BDA0010616E5/X13-05665.img
When you have downloaded this, rename it to name.iso
and use WinRAR or simular packers to decompress it to a
temporary directory.
Then start
and go to the plugins button
and DESELECT all settings and plugins where it says Multiboot.
Multiboot is not compatibe with this Windows 2003 version..
Also disable the Dial-In network.
Okay, now close the plugin settings and then
press the button to create the ISO CD.
Then after a few minutes it has created a BartPE directory and
an ISO file which you can just burn for instance with Nero.
This is then a working Windows XP BootCD with also the DriveImage XML
tool on there.
If you want to have a bootable USB drive, just then afterwards start
the UB*.exe program,
( It is the second EXE program in the
UBCD4Win folder, sorry
am not at that PC don´t remember the exact name right now)
that is in the same folder as the
and it will generate a bootable USB stick flash drive for you.
That is now a perfect Windows XP Live version with many nice tools
to repair WIndows XP installations or fix harddrive or boot errors.
Here is a list of the included tools:
List of tools included with Ultimate Boot CD for Windows®
Anti-Spyware Tools
aSquared Free    3.1.0.9    Scans remote hard drives for spyware, etc.
AdAware    1.06 SE    Scans remote hard drives for spyware, etc.
AVG AntiSpyware
CWShredder    2.16    Finds and removes traces of CoolWebSearch hijacker.
EzPCFix    ??    Helpful tool when trying to remove viruses, spyware, other troublesome advertising programs, and malware from your computer.
HiJackThis    2    Helpful tool when trying to remove viruses, spyware, other troublesome advertising programs, and malware. Not as good as EzPCFix.
Rootkitty    ?    Very new tool in development, searches a system for rootkits
Spy Bot    1.5.2    Effectively scans remote hard drives for spyware/malware!
Super AntiSpyware         Effectively scans remote hard drives for spyware/malware!
WinSock Fix    1.2    Used to repair WinSock errors
AntiVirus Tools
AVG Free    7.5.503    Excellent full featured freeware AntiVirus software
AVPersonal    7.04    Good full featured freeware AntiVirus software
Avast! Tool    1.0.211    Scans for a limited number of viruses
Kaspersky VRT         Free virus Removal Tool from Kaspersky
McAfee Stinger    2.6.0    Scans for a limited number of viruses
Applications
FireFox    2.0.0.11    Internet Browser
Irfanview    3.98    Compact image viewer
NotePad++    4.7.5    Powerful notepad replacement
Opera    9.25    Internet Browser
PDF Reader    1.3 B519    PDF viewer
Popcorn    1.74    Email Client
Scribe    1.87    Email Client
XPSetupLauncher    1.4    Allows you to perform unattended installs of XP from within BPE
CD Burning Applications
DeepBurner    1.5.1.192    Allows you to burn CD's in the BPE environment.
DVD RAM    4.2.2    DVD Burning software
Express Burn    1.08    CD Burning software
SmallCD    1.12    CD Burning software
Commercial software Plugins -note-:requires license and files to build
Ghost    8 & 11    Excellent imaging software
Kaspersky AV    6 & 7    Awesome AV software <Plugins for Version 6 and 7>
Disk Tools
        -Backup/Cloning
CopyWipe    1.14    Copies and/or securely erases hard drives
Disk Copy    N/A    Floppy disk copier
Disk Image    1.15    Creates and restores images of disks to files
DriveImage XML    1.18    Hard drive backup and cloning
ImgMaker    1.1    Create backup images of your Hard drive, no longer supported?
RawCopy    1.0    Used to transfer data directly to another drive when the original is faulty
SelfImage    1.1    Hard drive backup and cloning
        -Defrag
AusLogics Defrag    1.4.11.275    Hard disk defragmenter
Defraggler    1.1.0.50    Hard drive defragmenter
Dirms    1.2.20    Comand Line utility to defragement your entire drive
        -Diagnostic
Bst5    5.1.4    Bart's Stuff test. Small Win32 application for long time heavily stress testing storage devices. Supports testing at file and device levels.
chkdsk    N/A
DskChkup    1.1B1005    Allows you to monitor the SMART attributes of a hard drive
Disk Check    1.0.75    Utility to check disks for errors and benchmarking
HDTune    2.5    Hard disk utility that will: Benchmark, Error scan, display temperature, SMART heatlh information and provide other hard drive information
WinDLG    1.02    Western Digital HDD diagnostic software for Windows
        -Partition
Boot Build    1.0    Create, import, or export your boot sector, useful when damaged by viruses or physical damage
MbrFix    1.0.0.5    Fix or create Master boot record
MBRWiz    1.52    Master Boot Record Wizard
TestDisk    6.9    Tool to check and undelete partitions
        -Security
CCleaner    2.03.543
Drive Erase    1.02    Permanently erases data from hard disks, removable media, partitions, files and folders.
Disk Wipe    1.1    Securely wipes data from discs
Eraser    5.7    Completely remove sensitive data from your hard drive by overwriting it several times with carefully selected patterns
Index.dat Suite    2.8.6    A unique program that allows you not only to delete the index.dat files, temporary internet files, temp files, cookies and history, but it also allows you to view the index.dat files on your system.
File Management
        -Compression
IZArc    3.5 B3    Popular freeware compression tool.
7-Zip    4.57    Popular freeware compression tool.
        -Explorers
a43    2.45    File management
Agent Ransack    1.73    File search
freeCommander    2007.10a    File management
Space Monger    1.4    Graphical disk usage viewer tool.
Tiny Hexer    1.6.0.2    Hex editor
WinDir Stat    1.1    Disk usage statistics viewer and cleanup tool
xplorer2 Lite    1.3.0.2    EXCELLENT File management tool!!
        -Recovery
DBXtract    4.5    Repairs PST files for Outlook express
Disk Investigator    1.31    Display the true drive contents by bypassing the operating system and directly reading the raw drive sectors. View and search raw directories, files, clusters, and system sectors. Verify the effectiveness of file and disk wiping programs. Undelete previously deleted files
Fab's AutoBackup    1.2    Backup and restore personal settings like emails, documents, internet browser bookmarks
File Recovery    4.0    Data recovery for damaged files and erased partitions
Floppy Repair    1.0    Eliminates bad sectors of Floppy disk surface, does not hide bad sectors in the file system, as Scandisk like utilities, it really restores them
Free Undelete    1.0    Data recovery program for deleted files
Handy Recovery    1.0    Designed to restore files accidentally deleted from hard disks and floppy drives
Recovery Manager    1.5    Backup & Restore, Duplicate, Recover files accidentally deleted or from corrupted media, and Format Digital Flash Media
Recuva    1.10.223    File recovery program
Restoration    2.5.14    File Recovery, restore files that have been deleted from the Recycle Bin
UnChk    3    Recover CHK files
Swiss Knife    3.21    Useful tool to create, delete, and format partitions
Unstop Copier    1.9    Recovers files from disks with physical damage
Games        sorry, no sound
Arcade!    3.1.0.1    PacMan, Pong, Snake, Space Invaders, Tetris
MS Games    n/a    Freecell, Hearts, Minesweeper, Pinball, Spider
Same Game    1.0.0.1    Puzzle game
Linux Tools
Explore2fs    1.00    Allows exploration of Linux partitions in the Windows environment
R-Linux    1.0    Recovery utility for the Ext2FS file system
MultiBoot Tools
MemTest86+    2.0    Memory tester
Vista Recovery Console    n/a    Recovery console for Windows Vista
Network Tools
FileZilla    3.0.4.1    FTP Client
IP Sniffer    1.91.6    Fast IP scanner for Windows
IPScan    2.21    Fast IP scanner for Windows
LAN Monitor    1.3.5    Karen's
NetStumbler    0.4    Find wireless networks
Network ConfigTool    n/a    Tom's Network ConfigTool, to help setup network configuration settings before building UBCD4Win
NIC Speed    1.3    Bart's
nwdskpe         Novell's NetWare Client to access NetWare servers by IP/IPX
Putty    .60    Implementation of Telnet and SSH for Win32 and Unix platforms, along with an xterm terminal emulator
Real VNC Server    4.1.2    Remote control software which allows you to view and interact with one computer
Quick 'n Easy FTP Server    3.1    Easy FTP Server
Tight VNC Viewer    1.2.9    Remote control software package
UltraVNC    1 RC18    Remotely control a computer over any TCP/IP connection
VNC Neighborhood    1.1.9    VNC server TCP scanner, uses Microsoft Windows Networking features to locate computers in Microsoft Windows domains and workgroups
Password Tools
cmos    4.6    Find your CMOS password and/or replace it
PasswordPro    2.4.0.2    MD5, MD4, MySQL, SHA-1 hashes password recovery, password keeper, password generator, hash generator, dictionary generator, etc
Sala Password Renew    1.1 B    (re)set the passwords of any user that has a valid local account, create a new local user with administrator rights, and set administrator rights to existing user on your NT system
Registry Tools
Erunt    1.1i    Emergency Recovery Utility -Registry backup and restore
Fix HDC    n/a    Fix the Hard Drive Controller when replacing your motherboard on an XP system, possible replacement for Fix IDE?
Fix IDE    n/a    Fix the IDE Controller when replacing your motherboard on an XP system
RegBrws    1.2.2    Browses local/remote system registry using a specified account
RegCleaner
RegResWiz    1.0.0.4    Wizard that restores the registry to previous saved states
RegShot
ServicesPE
Windows Registry Analyzer
Shell Features
ASPI    N/A    CD Support
AutoRun    N/A    BPE functionality
atapi_824146    N/A    XP Patch
BartPE    5.1.4    small win32 application for long term heavy stress testing storage devices at the file and device level
CHM, HLP, WSH, USB Support    n/a    All features are supported/available thanks to the "core" of UBCD4Win
dcomlaunch    n/a    Launch DComLaunch service first -for SP2
Dialup    n/a    Ability to use your modem, you will need to create a modem driver plugin for your particular model. Email me for support, I will try to help
DosPE    1.0.6    DOS 16-bit support
GeoShell    N/A    Adds more "XP" feel, enhanced startbutton, quicklaunch, taskbar, etc.
Keyboard support         Keyboard mapping and "Onscreen keyboard"
MMC Update    2.0    Microsoft Management Console
mstsc    N/A    Remote desktop client
Mouse support         PS/2, Serial, and USB mouse support
nu2menu         Menu system
peinst         HD installation tool for PE
penetcfg         PE Network Configurator
PPOE2k3         PPPOE dialup network support for Win 2k3
PPOEXP         PPPOE dialup network support for XP
RAM Profiles    1.0    Creates a profiles in the RAM drive which allows several tools to work properly
UnxUtils         GNU utilities for Win32
VBdlls    5.0&6.0    Visual Basic DLL's, makes these runtime dll's available in PE
System Information Tools
        - Benchmark Tools
CPU Bench    4.0.06    CPU benchmarking software
Dead Pixel Tester    2.30    Used to help dead pixels on your LCD/TFT monitor
MemTest    3.2    Memory tester, please read manual.htm for instructions and advice
P95    23.8    Prime95, stress tester, popular with overclockers
Quick Bench
StraightMark    1.2.1    System benchmarking tool
        -Information & Diagnostic Tools
CPUz    2.44    Gathers information on some of the main devices in a system
Driver Wizard
KeyFinder    1.41    Will find your Windows installation key, both the PE and Windows versions are included
Nero InfoTool    3.0    Detailed drive and system information for your CD/DVD drives
SpeedFan
System Info    1.73    Provides detailed system information, network info., etc.
Unknown Devices    1.2    Helps discover what unknown devices in Device Manager really are
WinAudit    1.3    Audits your software and hardware configurations
WinCPUID    3.3    Displays the CPU information: Shows Frequency, Multiplier, Chipset Info. etc
WUL    1.21    Windows Update list, lists updates and patches installed on a system
UBCD4Win Exclusive Tools
The "Core"    n/a    An extremely complex "plugin" that provides a lot of additional XP functionality to UBCD4Win. Many of the "old" plugins have been consolidated into this "core" such as keyboard, onscreen keyboard, USB support, WSH support, and so much more!!
RamDrive         Purchased OEM license for the RamDrive driver. Provides up to a 2 Gigabyte RAM drive for UBCD4Win
Tom's MyInfo    n/a    Similar to BGInfo in the fact that it displays system information on the desktop
RunScanner    1.0.0.20    Registry redirector plugin developed by Paraglider. Used for launching spyware detector programs and has been tested with SpySweeper and Ad-Aware
Joshua's Localization    n/a    German language support and an easy way to change almost all dialogue to your native language
Enjoy !
Regards, Stefan.
hartiberlin
And here the latest application updates on this UBCD4Win
Version 3.22 Changes -Released:11/12/08
    * Feature- Grub4DOS support added to MultiBoot plugins
    * Feature- VC++ 2005 Runtime, several programs now require it
    * Feature- USB Hot Plug Plugin fixes
    * Feature- UBUSB
    * Added- CrossLoop
    * Added- GPU-z 0.2.8
    * Updated- All Anti-Spyware and Anti-Virus definitions updated 11/9/08
    * Updated- A-Squared 3.5.0.27
    * Updated- Auslogics DiskDefrag 1.4.16.308
    * Updated- AVG Free 7.5.524
    * Updated- CCleaner 2.12.660
    * Updated- CPU-z 1.48
    * Updated- Defraggler 1.03
    * Updated- DiskImg 1.45
    * Updated- DriveImage XML 2.02
    * Updated- Eraser 5.86a
    * Updated- ExpressBurn 4.15
    * Updated- FileZilla 3.1.3.1
    * Updated- FireFox 3.0.3
    * Updated- Foxit Reader 2.3.3309
    * Updated- FreeCommander 2008.06c
    * Updated- HijackThis 2.0.2
    * Updated- IDSuite.dat 2.10.1
    * Updated- ImgBurn 2.4.2
    * Updated- IPSniffer 1.97.1.2
    * Updated- Memtest 3.7
    * Updated- Notepad++ 5.0.3
    * Updated- nPOPuk 2.11
    * Updated- Opera 9.60
    * Updated- Recuva 1.19.350
    * Updated- RunScanner 1.0.0.22
    * Updated- SpeedFan 4.35
    * Updated- SpyBot S&D 1.6.0.30
    * Updated- Stinger 10.0.1.602
    * Updated- SuperAntispyware 4.21.1004
    * Updated- SysInfo 2008.09.08
    * Updated- TestDisk 6.10
    * Updated- TrueCrypt 6.01
    * Updated- Unstoppable Copier 3.56
    * Updated- WUL 1.23
    * Updated- xplorer2 1.71.4
    * Removed- VistaRD, unreliable download
    * Removed- PE2USB
So DriveImage XML is also there with the current version 2.02 !  :)
Regards, Stefan.
