Magnetic "Free Energy" designs released - finally!
Started by PaulLowrance, January 17, 2009, 02:06:01 PM
tak22
I agree, proof is of first importance. If a solenoid is fast enough, then it could be used for
either design to create the back/forth motion. Once you've got the timing set, then start
measuring either temperature or coil output. After a baseline is established you can start
trying different materials, coils, etc.
tak
PaulLowrance
Quote from: tak22 on January 20, 2009, 12:06:45 PM
tak
Thanks tak. You seem to have a good handle on such a task.
Some thoughts:
Making the black rods (high magnetic viscosity) -- A roll of carbon steel welding wire cut into segments, each coated with a thin layer of say paint, and then carefully grouped together to forum a laminated rod. Harbor Freight has a roll for $7 -->
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42917
The gray rod (low magnetic viscosity) could perhaps be cut from an *ultra* high frequency ferrite rod. Amidon sells ferrite rods. They're not exactly ultra high frequency, but should be good enough; e.g., Amidon part number R61-050-400 costs $7
https://www.amidoncorp.com
Perhaps someone knows of higher performance ferrite rods. IMO, one of the best choices is a piece of magnetite, but it would have to be cut into shape. You'll find people at metal detecting forums who will sell magnetite real cheap.
The first mechanical design in moving the gray rod could be aggressive since efficiency is not the first concern, where decreasing the gray rods temperature is. If it takes a lawnmower motor to achieve the task, then so be it, lol. Success will go down in history. The machine will be displayed in a historical museum.
PL
PaulLowrance
Quote from: Craigy on January 19, 2009, 06:34:45 PMThinking a bit more i see that in your 2 disc design everything switches or fires at once and all coils would essentially be wired in parrallel thus avoiding messy contacts that would be required on my brainstorming idea.
The coil for the gray rod will most likely require different amount of current than the black rods. Hopefully it would not take too long to adjust the currents to obtain optimum temperature drop.
PL
Craigy
hi Paul.
I found this patent a year or so ago, when i was first looking at carnot cycles and magnets and their currie temps . It basically backs you ideas up, but does it in a slightly different way , in the patent there is a circulating ferro fluid...
http://www.google.com/patents?vid=USPAT6725668&id=mS8QAAAAEBAJ&pg=RA1-PA1&dq=+magneto+calorific+effect+in+magnets#PPA1-IA1,M1
Thermodynamic cycles and method for generating electricity
Abstract
An apparatus for performing a thermodynamic cycle comprising: a sample having a ferromagnetic phase transition temperature; means to magnetise the sample above the ferromagnetic phase transition temperature of the sample; and means to cool the sample to a temperature that is below the ferromagnetic phase transition temperature thereof, wherein the demagnetisation of the sample whilst the sample is below the ferromagnetic phase transition temperature thereof causes the generation of an independent magnetic flux. Also disclosed is a method of converting energy, comprising the steps of: providing a sample having a ferromagnetic transition temperature; magnetising the sample while the sample is above the ferromagnetic transition temperature thereof; allowing the sample to demagnetise while the sample is below the ferromagnetic transition temperature thereof, the demagnetisation of the sample causing an independent magnetic flux; and converting at least some of the independent magnetic...
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
tak22
Paul,
Is solid magnetite a must have? Could a DIY cast rod of magnetite sand and resin work well enough?
tak
