oscillator circuit ?
Started by nitinnun, January 23, 2009, 10:57:56 AM
nitinnun
how do i configure an oscillator circuit,
to turn a source of DC electricity (9 volt battery?),
into AC electricity ?
if ever i needed a straight forward answer, it is on how to do this.
preferably step by step.
don't tell me to go to google.
google is 2 steps above useless, for things like this.
don't send me to a website with endless blah blah not-what-i-need.
each word that i read, tortures the nerves in my right brain matter.
just say it.
z.monkey
This is the circuit I used to generate a sinewave.
http://hobby_elec.piclist.com/e_ckt18.htm
Connect the output of this circuit to the load, and the other side of the load to ground.
I needed mo amps, so I build a bridge amplifier to boost the output...
You can look at the schematic and the bridge amplifier here...
http://www.overunity.com/index.php?action=tpmod;dl=item181
So why ya playing with AC now?  Gonna catch a wave?
Goodwill to All, for All is One!
nitinnun
more like i'm going to kick a magnetic field in the teeth, with frequency.
*wink* *wink*
i also read that high frequency magnetic fields, make people feel better.
and even heal them of injury and disease.
nitinnun
Quote from: Loner on January 23, 2009, 03:39:47 PM
How clean a sine, or is square OK?
How much output?
Would a 555 timer do?
What Frequency Range?
Adjustable?
Stability?  (Just for a couple hints....)
[ also, a good suggestion is quality vs component count, expense, etc.. ]
i doubt it matters if it is sine or square.
i doubt it matters how dirty the signal is, either.
if you showed a 30 volt output at half an amp, i could adjust that, to whatever i wanted.
the frequency doesn't have to be adjustable.
couldn't i avoid an IC chip, by connecting together a bunch of transistors?
the more transistors, the more oscillations, the higher the frequency?
i wanted to try 120 hertz,
180 hertz,
240 hertz,
300 hertz,
and 360 hertz.
any of those, would be fine.
stability doesn't matter much.
i can worry about stablity, after i get a prototype working.
minimum components,
at minimum cost,
are important.
i want it to be as simple/cheap as possible, while still working.
resonanceman
Quote from: nitinnun on January 23, 2009, 10:57:56 AM
nitinnun
I  have not made  one yet but I have been planning  a similar  project .
I was  going to make an oscillator using  an LC resonant circuit  driven by a PWM ( pulse  width modulator )
I had links  for  how to make these things but lost them when I had to reformat my hard drive a month ago .
I remember that  a datasheet  on  a 555 timer showed how to make  a  PWM and other devices with a 555chip
They say that  a LC circuit  will ring when  hit  with  a  pulse of energy .
I planned to hit  it with a pulse from the PWM once each cycle .
The  voltage used could be  anything that  a 555 chip can handle ......
gary
