Captain Hans Coler (Kohler) Magnetstromapparat (Magnet Power Apparatus)
Started by Michelinho, January 24, 2009, 09:12:26 PM
gotoluc
Thank you Michel for taking the time to write about your experiment and ideas of your U magnet Neo keeper setup.
Very interesting!... I hope you continue to study the effects.
Please do keep us informed of the development if you chose to do so.
Thanks for sharing.
Luc
sushimoto
Quote from: neptune on March 01, 2009, 11:24:32 AM
Hi Sushi. I understand what you are saying about the needs of Germany after the War. What I would really like to see would be Hans Kohlers work benefit the whole of Mankind, as I am sure we all would. It just seems crazy that the UK government would keep this secret for so many years and do nothing with it.
You are right and i understood it in the way you described it.
All the hidden findings concerning energy, pollution and such
should belong to mankind instead of governments which are treating findings
as "secret" and for military use only.
... Or to keep "common people" dependent from industrial economy...
-dumb sheeps-
Best regards,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
albator10
To Michelinho
Hi,
With a setup like this (not mine)
It will be easier for you to adjust the magnets
Michelinho
Hi albator10,
That replication is nice, too nice as it doesn't work. Too much ferrous or non ferrous hardware to steer the magnetic field. It would be better with nylon screws, threaded rods and nuts plus it is still manual adjustment but more work than the wood sliders and wing nuts. Also the conducting traces under the Plexiglas pass right where the magnetic fields interact. I checked it out when I was researching the Magnetstromapparatus and when I saw that it did not work, I decided to do it like the replication in the first post of this thread.
Take care,
Michel
sushimoto
Quote from: Michelinho on February 28, 2009, 04:33:55 PM
Hi sushi moto,
Yes the whole process is time consuming as it is the only thing that will show peak output. It could be done with step motors or linear motors and gears or strap with a programmable chip that would pause and compare various settings position vs electrical output. The tuning has to be done with magnet positioning first and then different tuning coil settings for each magnet movement.
But that would take part of the fun out.  ;)
Take care,
Michel
Hi Michel,
I would not bring in electronics and magnetic motors because these are elements,
which were not available at Kohler's time.
Such elemnts are disturbing magnetic flux in the replication.
I would do it in the way, "tricky gemans" at that decade had done it.
Its a wooden (plexi) disc with "spiralic" inserts. Hard to describe.
best, sushimoto
