My new setup.
Started by ben8807, January 24, 2009, 10:57:47 PM
ben8807
Using an off the shelf function generator because I need one that is easy to sweep and dial in, and this way I don't need to worry about R&D or the failure being in my test equipment. Also, I know that this should not generate power. I'm not trying to. I'm trying to get some of the other results. I want to get high voltage out of a single coil with an RF input, also I would like to see some sort of gyroscopic action. Two frequency generators will be for later, probably need another off the shelf function generator so that I can sweep both of them easily since pulsing a freq through one winding will cause a change in resonance in the other and vice versa. 555 Timers will be great if and when I have a non test bench model assuming I can get a good sin wave at 4mhz. First though gotta get a single coil to work.
But I do appreciate the insight magpie, well thought out comments are kinda rare in this forum.
ben8807
Not getting the form of resonance I want. Quite a disappointment. Will post more as I get it.
Bruce_TPU
Quote from: ben8807 on March 31, 2009, 01:48:59 AM
Well out of the three ways of replication here is what you get:
Blind experimentation: Nothing. If the basic workings of a tpu were common and the result was easy to achieve then we would see unintentional use of this effect in devices not designed for it. Other than the accounts of old TVs exploding there is nothing. So we must conclude that the design must be specific and deliberate to use the forces that cause power generation.
Understanding the underlying physics: Sure, if you can do that then it should be reasonable to produce such a device, but other than blind speculation and pseudoscientific rants we don't have much to work with. If you find a bit of theory that seems solid and supports the idea then run with it.
Copying successful devices: Well we know that they are some form of toroidal coil. We know that Steven Mark obfuscated the actual workings of the device as much as possible and that he only told investors little tidbits of information within the misinformation. Don't believe everything written about the device, believe your eyes, watch the videos, but understand that anything spoken or written is at best a half truth.
I have a very crude theory about the device, but so far it hasn't stood up to experimentation. I will continue my experimentation though and if nothing else I hope to have a new transformer design.
Actually, he gave us everything we needed to know, to study, to replicate the tech.  He wanted us to have "understanding" and not just copy.  I understand, so now I design, and then I build.  And then?  Post a blueprint here?  It's already been done by SM, and few if any listen.  LOL  Human nature.
If you want to experiment, build three tube amps, with VHF triodes for color television.  Build a Magnetic Loop Antenna out of Litz wire to resonate at the combined frequency.  Pulse said control wires wrapped around the collector with F1, F2 and F3.  Add a sprinkle of bias to the collector to get them magnets rolling and wahla, you have a working SM style TPU.
Now, what I just wrote what seems like poppycock to 99 percent of you, because you do not yet have the understanding.  Read GK's post above, it was well written.  Then put your head back into what SM wrote and see what you see.  For years now I have been striving to understand, with a piece here and then a piece there.  Then, it just came together.  The same way with GK and others.
So, hang in there.  Just because life is quite here does not mean things aren't being experimented with.  Plus I know of other groups, at least three, not even associated with replicating the SM TPU, working on their own Toroidal devices. Though so far, SM's would seem to put out the most wattage, but has those eddy current problems.
P.S.  Oh, once you understand, you will NEVER forget the kill switch OR the over heat sensor embedded in the collector.  I promise you that is part of my design.  LOL
giantkiller
Take your TPUs and straighten them out.
Wahla! You have Lakhovsky, Koone.
http://educate-yourself.org/be/lakhovskyindex.shtml
http://www.pat2pdf.org/patents/pat2351055.pdf
http://www.pat2pdf.org/patents/pat1962565.pdf
Leave them in a ring and you have Rife, Dotto, Steven Mark, Stan Deyo!
http://www.rife.org/
http://keelynet.com/biology/dotto.htm
http://www.overunity.com
http://www.google.com/search?hl=en&q=stan+deyo  I emailed him and he replied 'Pulsed D.C.'
This guy got in trouble with the A.M.A. and F.D.A.
Koone
http://www.pat2pdf.org/patents/pat6933819.pdf
Nobody would believe his witnesses. I saw the news report.
Don't just build. But see a pattern first from the masters.
Look at figure #3 in pat1962565.pdf. Do you see the Tesla Wireless Magnifier? You should!
Look at figure #2 in pat2351055.pdf. Do you see the TPU or canon balls? You should!
Look at figure #8 in pat2351055.pdf. Do you see the plate #61? I used aluminum. That was really stupid! The generated magnetic waves compressed against the plate and shot of the sides in very narrow emmissions. It stung! Dansway suggested that. You wanna get hurt? I can hurt you...
Bearden parasaid 'There are many ways to snag the Aether'.
All these devices transmit and receive. If you can't do the physics or the electronics then at least look for the mechanical patterns in the diagrams or the devices.
Someone posted about my Leedskalnin bottle coils and said the copper didn't have enough mass to transmit the kind of power it would take to levitate those slabs into place. Too bad. What people fail to notice is the quarry right next store to Coral Castle. It is a square box and the slabs were lifted straight out from the solid ground. The neighbors never heard a sound. Kinda gives a deeper meaning to the term 'Free-mason' now doesn't it.
If this doesn't help then follow my previous advice and get out now before you really go broke or hurt yourself. Seriously... These are really easy to do before you even realize it.
What does this have to do with the TPU? You will never be the same...
--giantkiller. How's that for cryptic?
P.S. Find the tune 'Bargain' by the Who. The words will enlighten you to your addiction. ;)
P.S.S. Bring it on!
Grumpy
What is SM really meant "three different pulse widths" when he said "three frequencies"?
(The large TPU in the video only had two frequencies.)
If you can squeeze the hose with two hands, you can squeeze it faster with three hands or you can stick with two hands and pass it through more than one pump.  In the more than one pump case, the pulse width would be smaller in each pump stage, or the repetition rate faster, or both.
The water in the hose is already moving as it reaches the subsequent pump stages, so you squeeze faster (higher frequency, shorter pulse).
Yep.  Pretty sure that is what he meant.
        -Frank Edwards
