How the Gray Tube Circuit Works
Started by qiman, January 29, 2009, 03:45:58 AM
Dogs
This is an excellent thread. Great analysis from Aaron and qiman. Thanks guys!
"Splitting the Positive"
It seems to me that the simplicity of Cold energy is to create a HV vacuum from the sudden discharge of 2 equally balanced capacitors. As the flow of electrons actually goes from the negative to the positive. A capacitor actually has an implosive action, sucking up electrons as it discharges.
So a synchronized HV discharge between 2 balanced caps will create an electron vacuum between them. Nature abhores a vacuum and fills it with something else; Cold energy?
I thought about this and I drew up a circuit that I think gets to the point. I'll try it out tomorrow.
Does it look like it will work?
Is there something else that the tubes do that bring about that extra kick of energy?
quarktoo
Quote from: Dogs on June 26, 2009, 06:36:44 AM
Yeah, make it work. Check out Naudin's MHOG experiment. Replace copper flask with copper coil. The secret to Gray tube is the H2 to H1 transmute.
You might check out some of Jerry Bayles's work if you are up to the science.
http://www.electrogravity.com/HydDisEnergy/HydDisEnergy_1.pdf
Notice the yellow graphic mid document? That is the principle of sustaining the burn with ultraviolet that Stan Meyer talked about.
http://www.electrogravity.com/EnergyPipe/EnergyPipe_Add1.pdf
Sorry to say, Aaron missed the boat on this one. It's the hydrogen.
The water spark plug has absolutely nothing to do with the gray tube. The two coils that someone quoted as being present near the gray tube were just the autoformers used to produce the arc.
alan
Can you pls point out where you saw or heard this?
quarktoo
Quote from: alan on June 27, 2009, 11:56:41 AM
Most of his lectures Alan. He alludes to it in this one and I think video 7 of the Colorado lectures in better detail.
http://www.youtube.com/watch?v=HoBbnqcfJWs
All of these water fuel inventions worked the same way  - Puharich, Meyer, Mills. Read and listen to what they are telling you and the terms they use. Hydrogen fracturing - Meyer / hydrogen shattering - Puharich. Reducing the energy state, etc. They all worked the same way and it is hardly a new trick.
Notice Meyer states that his oxygen atom only has 4 electrons? That is some powerful ozone huh?
