How the Gray Tube Circuit Works
Started by qiman, January 29, 2009, 03:45:58 AM
alan
I know he talked red laser and leds to energize and 'prime' the gasses, but nowhere have I seen him mention UV, I'll check the video.
Ozone is very probable indeed:
http://en.wikipedia.org/wiki/File:Ozone-resonance-Lewis-2D.png
quarktoo
Quote from: alan on June 27, 2009, 02:02:20 PM
[hmm I think I don't understand the pic above, 1 line is 2 sharing electrons?]
Alan, there is a big difference between making a powerful form of ozone using red LED lasers and sustaining the burn of a sub critical hydrogen explosion.
I seem to recall oxygen having a resonant frequency of 752nm which is red and a part of the air gas processor. Read the patent.
Meyer patented and documented in his notes a hydrogen laser which emits UV light. You can read these things for yourself in his notes and patents.
Dogs
quarktoo, if H2 to H1 transmutation is useful, it seems to me that it may work to run an SM WFC as the load.
I simplified the circuit. Per Rosemary Ainslie's theory, its the CEMF that brings about ou at the inductive load. A discharging cap causes electrons to travel toward the cap. 2 caps discarging with an inductive load between them causes and electron vacuum at the inductive load. When the 2 caps discharge they create CEMF (Counter Electromotive Force), 2 Electromotive forces working against each other, creating an electron vacuum between them.
The universe abhores a vacuum... how the vacuum is filled is speculation at this point.
quarktoo
Dogs,
You used a resistive element symbol to describe an inductive load, a switch to indicate both a relay and probably a transistor and your secondary  isn't grounded. Good luck with your theory.
Dogs
Thanks quarktoo,
You are right... The load should be inductive, something like a transformer, the secondary coil should connect to the negative of the primary, and the switches should ideally be something like HV HF opto-couplers or IGBTs that are controlled by some oscillators, details, details.
Just a rough idea of the basic concept...
Actually kind of looks like Tesla's patent # US Patent 568,176 Apparatus For Producing Electric Currents Of High Frequency And Potential.
Especially if one were to use the single capacitor variant of the circuit.
