HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
johnbostick
Quote from: TheBuzz on February 09, 2009, 07:23:50 AM
March 1994 US 5293857
In this patent Stan brings it all together with the management system, the air gas processor is fully disclosed, the laser, the injectors, everything. At this point in the evolution there are apparently no tube cells in the system.
Now look at the front cover of the box:
http://www.overunity.com/index.php?topic=6702.msg155635#msg155635
Notice the patent number 5297857? That is the last patent Stan filed on the water car and there were no tube cells at that point.
That coil is the HV coil (VIC) that powers the electrodes in the ozone generator in the air gas processor. That coil is bank wound and that is how we wind a high voltage coil to prevent the layers from shorting. The rule is something like ten winds per layer and each layer has to be insulated.
This is the last patent Meyer filed on the water car and it was fully evolved for commercial production at that point. There were no tube cells in the process at that point and the front cover of that box proves what it is.
And you wonder why you don't figure it out or why people don't contribute? You can't fix that.
Buzz,
Please try to be as honest as you can. Try to refain from insulting these people. You know your not all that or you would have some proof in your research.  If you do prove it.
Just because you don’t see it doesn’t mean it’s not real.
kinesisfilms
johnbostick you are correct about the waterfuel cell in that patent.....
there are two version at first....you show this version (note how there is a fuel cell separate from the injectors.)
http://i2.photobucket.com/albums/y2/kinesisfilms/entiresystem.jpg
then it moved to this version...(don't mind the red circles that was used for something else a while ago)...note how there is no longer a fuel cell.
http://i2.photobucket.com/albums/y2/kinesisfilms/donkey.jpg
so johnbostick you are correct for that version.
let buzz keep talking he will just consistently prove himself incorrect.
once again there were many version to this method.....so don't look at every piece and think it is the final...you have to understand the conceptual parts first.
i can't stand to keep reading his bullshit.
johnbostick
Thanks Kinesisfim
I am new at this and do need a little direction.  My plan is to share all I find.  I want to be apart of this research.
ramset
A LOT OF THICK SKINNED FELLOWS OVER HERE
Thats good , very good
Thats what its gonna take to see this through
The really cool thing is
Its out there, this is going to happen!!
And this is just the tip of the Iceberg
Chet
Thanks Grandma
kinesisfilms
Quote from: TheBuzz on February 09, 2009, 10:24:47 PM
Think it though!
through*
and of course there were many versions but you were wrong, dependtard.
please continue to over-complicate yourself....keep it simple STUPID....meyers directed that towards people like you.
