HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
dankie
dankie
Quote from: TheBuzz on February 10, 2009, 09:15:19 PM
I am fully aware of the difference between longitudinal and transverse waves and how two opposing longitudinal waves create matter. I have posted much information on this subject on this web site.
My problem with you is you are a fucking dependtard like hydrostupid with all your I have some big secret and look at me I need attention. Your pack mentality and craving for adoration is what drives you, not an attempt to understand how it works.
The primary of that coil was electricity flowing in two different directions. The wire is barely inductive conductive if at all. I have wound that coil twice now and it does not produce any electricity.
Now if you look at the drawing in Meyer's notes, you see a pulse going into the primary. Since the coil can't generate electricity (transform) where is the electricity coming from?
The coils is designed to remove electrons from a wire that is attached to a injector OR a tube cell - electron extraction.
I would post a patent for an accelerator coil that would clear it up for you but you and your dependtard pack cabal of idiots have done nothing but turf the water fuel movement from day one.
That's O.K. Dankie, unlike you there are a lot of people like me that wind coil roughly once a day and actually know what we are talking about. Simple? Yeah,.you are simple. All idiots are.
The fact that it is a retrofit has nothing to do with how it functions at a EM level.
http://www.youtube.com/watch?v=IjEXnsPbzSg
Wow great , it shouldnt eat too much power then , electricity is not the point my friend . VOLTAGE is . Thx for confirming to me he proof of concept , even tho I know you are probably lying .
In an electronic circuit theres voltage and amp flow , VOLTAGE IS NOT CONSUMED IN AN ELCTRICAL CIRCUIT -
-Stanley Meyers
plz watch this video , Stan gives a quick lesson about this .
dankie
Quote from: TheBuzz on February 10, 2009, 09:34:02 PM
Do you really think I need to watch a video to know that a circuit contains current and amp flow? I wrote a theory about what electricity is and how it gets produced at a below sub-sub atomic level. Nobody has proven it wrong or even challenged it. Pretty sure I know something about that subject.
BTW  - The wire I used was paddle wire. .5 mil and ohms out at 7 ohms per foot. Where did Meyer claim 20?
You paid $3000 for your wire Einstein, I paid $3.
your point ? Individual portions are cheaper. ;D
Somebody had to do it . Somebody had to come up with the money all by himself and buy thousand of dollars of wire .
Meyers never specifies any resistance value exept that typo. This is the ohmic value of 36 AWG 430FR is 19.775 ohms per foot . It makes perfect sense that Meyers would have used this alloy, it used in fuel injectors because of its low coercivity and high permeability , it is used to make more powerful more compact magnetic components but "doesnt stick" ... Read more plz , everything Meyers says is on Q and perfectly coherent with what Carpenter is saying .
Now normally this never comes in wire form, never this thin anyways  , it is used as a core material usually ...
All the info is there
http://waterfuelcell.org/phpBB2/viewtopic.php?t=1185
kinesisfilms
Quote from: kinesisfilms on February 08, 2009, 02:41:16 PM
it can be done with copper....too a certain voltage level.....after that the amount of copper needed gets a bit ridiculous.....remember in stans patents of his earlier vic coil it was constructed with copper.
so to achieve the injector/ionization method voltages of 40kv must be obtained which can be done with wire consisting of a higher resistance but must still have an inductance factor.
wow you are an idiot buzz i said this in the beginning.....also about your step charging lie coming from the power source......
here is your image that you made in red.....mine is blue
NOTICE THAT THE INPUT IS A FULL WAVE RECITIFICATION OF AN AC CURRENT VIA A BRIDGE RECTIFIER.......THE OUTPUT IS THE SAME FULL BRIDGE RECITIFICATION BUT WITH GATING......WHERE IS THE STEP CHARGING COMING FROM THE SOURCE???...oh that's right it doesn't happen that way from the source.....the source is a constant pulse and inside the capacitor step charging occurs......even for the water injectors there is step charging going on the only difference is a step charge takes a fraction of a moment...therefore making it seem like the instant thermal explosion of water.
wave 1 is what comes out of the stepped up isolated pulse transformer and into the VIC......wave 2 is what comes out of the vic and is further enhanced. wave 3 is what is sent into the water capacitor and the diagonal line is how the water capacitor builds a charge......i can prove this IDENTICALLY ON MY OSCILLOSCOPE.
once again you are a fool you your cavitation, and your magneto bullshit.....the thing you have highlighted is if anything to induce gating.
kinesisfilms
Quote from: TheBuzz on February 10, 2009, 11:11:53 PM
That does not prove anything. I have never seen a water cap charge without a spark gap.
The space in the mark space was there to keep the cap from going into infinity and arcing over - boom.
haha you have never seen one eh?.....then you aren't using voltage potential, amperage must be cut to a minimum of 1/1000th.
and no the gating space has nothing to do with noises or child "booms and bangs"
the space if there for an LC resonance to occur....i URGE you to READ the FIRST SECTION of the TECHNICAL BRIEF......there is a reason why the conceptual part comes first.....so people like YOU...can realize what is meant by K.I.S.S.
BOOM! hahahahahah NO.
OH AND EDIT:.....THE CAP WILL NEVER GO TO INFINITY....JACKOFF.
