DEK motor with U-coreless coil or Lenz boxing against Lentz
Started by woopy, February 02, 2009, 03:31:57 PM
woopy
@all
in  process  in the workshop and waiting for my timer    why not powering the pendulum of a Milkovic  2 stage oscillator with a UCC
in the picture the pendulum is a stack of magnets      and now let's make the circuit to time it right
the wheel in the middle works with a ratchet system     at the present it is  much too crude to be effective   but let's experiment  we will anyway get something interesting ;D
good luck
Laurent
Kator01
Hello Laurent,
this chariot-pendulum : how did you power it ?
Via the coils ?
Do you have a link to the original website where there is a description of this device ?
Really good stuff Laurent
kator
woopy I have a few predictions to your motor and I would feel real honored if you tried them out?
First I predict your motor will work as good if you used two (or even three) separate oppositely wound coils instead of a single U coil.
My second prediction concerns shielding one pole of the magnets. I predict this will give you substantially better results. You'll need to shield the pole that enters these coils first. Shielding  should not be perfect. This prediction can be tried without the first to see if it's true.
And my third prediction. Instead of shielding them you could use two magnets stuck together and repelling each other on the rotor.
All these predictions may be wrong but I would REALLY appreciate it if you experimented with them.
woopy
@Kator
no  i do not use coil for propelling the chariot  i only used the Hard drive axis that i i use to test the UCC by pendeling magnets through the UCC
i mean that the chariot works only with gravity    i simply let the 2 pendulum "fall down" by gravity  and the chariot  go forward  as Milkovic does with its chariot  on his desk in the video of its original site. You can get it very easily  with Google  simply type MILKOVIC and you get a lot of info on this man and his very interesting work.
@ Broli
thank's   but can you be more precise     i have seen that you are  a very good designer     so some pictures would be  helping
"@Nieves
thank's for sharing
very nice work
are you solving the high voltage versus power output ??
cheers
Laurent
nievesoliveras
Quote from: woopy on February 25, 2009, 04:00:57 PM
"@Nieves
thank's for sharing
very nice work
cheers
Laurent
What I am trying to solve is the voltage disappearing mistery. The voltage is on the batteries until you use them with a load, that the voltage just disappear.
The circuit seems to charge the battery, but the charged battery cannot be used.
Jesus
