Lenzless rotation using radially (update: axially works too) magnetized PM.
Started by broli, February 02, 2009, 04:22:05 PM
wizkycho
Hi broli !
can't wait to see your experiment, where did you stuck ?
Wiz
I got stuck at the tape and junk part  ;D. These experiments look like some 3 year old child has put them together, I mostly use tape and junk stuff. Every time I want to do an experiment I get too annoyed by stupid hindrances. By just thinking of stuff I have learned more than doing experiments in this last period. But I currently have a very small palm sized proof of concept in mind. It uses an electromagnet instead of a permanent one. And should show the principle as well. I'm going to make a rendition of and attach it in a moment.
It's kind of ironic that I went full circle and ended up where I started. I'm still puzzled about many things of the homopolar motor does and doesn't (like newtons third law). I thought I learned a lot until all the knowledge collapsed on me and left me naked. So basically I ended back at the radially magnetized magnets.
I have two concepts now. One is shown below and the other is a straightforward modification of it. The one shown below also acts as a generator, meaning there's "Lenz effect". This is because the charge moves along the electric field AND the direction of rotation. So this gives a counter force back in the form of an electrical field which halts the current. If this works it would still be superior to an old skool DC motor though. As there's no polarity flip and the head aches that come with that  Flipping polarity also wakes the self induction up of the coil which is another bad factor (sparks and all that other good stuff). So it's a pretty efficient generator.
Anyways the other design is no different from the below one. You just switch roles. The wires become the stator and the magnet becomes the rotor. IF (this is where I have been puzzled about a month long) this works there's no Lenz effect,because charge is only moving in one direction. Instead the reaction force of the Lorentz force acts on the atomic magnetic dipoles which cause it to rotate until it explodes.
As a side note. The magnet can be made like mentioned in my other thread about radially magnetizing materials. In this case two pancake coils on both sides of an iron ring would be enough to amplify the field. Best case would be of course making permanent ones.
petersone
Hi broli and all
for me,I can't wait for the next installment,anything to do with lenzless generation gets my attention,so I'm sure a lot are watching.
peter
Quote from: petersone on March 03, 2009, 12:49:39 PM
Hi broli and all
peter
Thanks, the more the merrier.
I today realized there's nothing wrong with the old concepts. I just got confused with all the knowledge. All you do is use newtons third law. The reaction force is doing work on the MASS of the magnet while the field remains the same. Can't get any easier than that. The Work-Energy theorem doesn't count for electromagnetism as the force does not get displaced even though the mass does. I believe this hasn't been used in the past because of the mass of a magnet versus its magnetic strength. So neodymium magnets are really good for this, as they can be 20 times stronger at the same size.
Also I gave up on home experimentation. I'm looking for some technical schools that allow me to make parts with their machines. I'm getting nowhere with duct tape and the few resources I have; If anyone is willing to aid with the experimentation it would be greatly appreciated.
