Peter Lindemann, The Mechanical Engine: A Re-Evolution of Bessler's Wheel
Started by hartiberlin, February 03, 2009, 11:21:29 AM
mindsweeper
What an unexpected post,  :-\
rlortie, you should be proud, I feel backing off now will only cause to confuse and cast doubt...
hey ho...
rlortie
Quote from: mindsweeper on February 03, 2009, 03:40:53 PM
Did Bessler not advertise his wheel as a "pendulum wheel" when he invited the 1st group of people to his house for demonstration, I think he did.
@rlortie, if this is your design then hats off to you, it's a marvelous design and I hope people will build and hopefully prove the design.
@mindsweeper,
No! this is not my design and I wish to state that with great adamant!  I believe in giving credit where and when due, something some appear to ignore or intentionally avoid.
Yes I have been involved with the design and have had  it in my possession since shortly after the dates given on the paper.  I will divulge more if and when this thread becomes more analytical involved.
As for Bessler, his opening words to get your attention and interest was: "My machine will barely run with one cross bar, but when I add more".... Not an exact quote but close, thanks to John Collins.
Ralph
Thaelin
Rlortie:
     My wheel will barely run with one weight set too. Add the second and your off and running.
My wheel is electric assisted tho, so a different animal it is.
thaelin
mindsweeper
Personally the C/M is without doubt offset, the question is will the pendulum have enough energy from the spring to return to the capture ratchet.
I cannot say and am attempting to replicate in WM2D but it's a hard design to replicate.
wattsup
At point #3, that ball WILL NOT reach the ratchet because it has to swing back against the wheel that is turning clockwise (hope it's turing clockwise). Since that is the main point where any potential gain can occur, this design, in my opinion, is a medium maybe.
The other and greatest point is the ball (weight transfer) to wheel weight (momentum) ratio. The balls should be a good 2-3 times bigger then drawn to help create any meaningful momentum. I learned that one the hard way. This means if the ball at #3 position is the only chance to create an off balance, then that off balance has to be greater then all the friction of the wheel including the friction involved incluing at #2 to release the ball.
But I like the design.
