Krystina NL possible OU Trafo ?
Started by wizkycho, February 05, 2009, 12:15:01 PM
wizkycho
Hi all !
I just uploaded this video that I think can not be forgotten without complete analisys
(krystina.nl page is down)
http://www.youtube.com/watch?v=dEEaAwwGTZM
amperage drops drastically from 4.7A to 1.8A - motor on the other hand accelerates
this might be solid state OU?
what happed with Mr. Lenz here (forgot to come to this trafo) ?
material for trafo ?
any gaps in core ?
n of coil wounds ?
type of coil ?
In is DC pulsed - but what freq and duty ?
motor is DC? - any greatz and cond. at output ?
please krystina.nl and all that knows of her work to describe this setup further. allso energy in/out would be easily meassured
(allso I will put down video if demanded)
has it been done ?
Wiz
AhuraMazda
wizkycho
I think for safe keeping you should post everything else you have from kristina.nl because it looks like they never exsisted!
gyulasun
Hello Wiz,
The video is explained by Nali2001 in the Simple to make Hilden-Brand style motor thread (by the way it is still downloadable from either megaupload.com or mediafire.com see links below to show them).
See this link for the explanation (and also download) http://www.overunity.com/index.php?topic=2222.msg134958#msg134958
and for download only if someone needs it: http://www.overunity.com/index.php?topic=2222.msg134958#msg134958
So when you go through you understand the purpose of that test.
I noticed your mail on the magnetic transistor here on the forum,  have you made some progress?
Regards,  Gyula
PS AhuraMazda:  kristina.nl  (not sure on correct spelling) used to a host server for Nali2001, not any more.
wizkycho
Hi !
since at my work (right now) I can not view/download *.wmv (due to someones "beautifull" work on firewall - other video extensions work so it not bandwidth they preserving i'ts just stupidity) and youtube is not clear enough. i can not be 100% sure but i think at second equation (when amperage drops) Nali2000 made an mistake in equation and if *.wmv is watched A-meter has 0,1,4,8 written numerically and between 1A and 4A are 5 segments, so my reading of this wopud be 1.8A not 2.7A
so watts would (by analogy to his equation) be 6V(50%dtc)*1.8A=10.8W not 16.8W
quote from Nali2000:
"...But with the magnets in the 'good' position you are looking at (12x2.7)/2=16.8watt. Of course I was too stupid back then to measure the watt output...
So who knows the real efficiency..."
Please Nali2000 remake this setup and do those Watt meassurements with some greatz and Cap. it would be bad if we overlooked Solid State FE device that easily.!!!
btw. are those female hands on video ?
thanks
wiz
Quote from: wizkycho on February 06, 2009, 09:34:45 AM
Hi !
If it's stupidity then just be smarter. Here's a solution http://dlatwork.com/.
