FIRST HOME COLD NUCLEAR FUSION REACTOR ALREADY IN POLAND.
Started by Doctor No, February 05, 2009, 05:14:59 PM
e2matrix
.3gp files are a low quality video typically from cell phones or the like.  Gomplayer will view it with the codec's that come with it or it will auto download them for you.  Just don't crank up the volume too much with headphones as it's a very loud screeching video.
   Are they selling these CF units somewhere in Poland?
Dr Adolf Nowak
Thanks for file conversion. More films can viewed on YT. We offer DRJ200 already from V2009, but officialy only from V2010, 90 birthday of K. Wojtyla (JP2). All in all this and other more powerful CF machines could go over water thanks his paceful work to the World. And to make this work life, the knowledge about this more powerful nuclear engines was given for free to Russia, for hands our good neighbor V. V. This should improve strategic imbalance between superpowers of which was little known, for KGB too.        Aber, zuruck nach DRJ.               The serie is basing on small engines uses same workhead. It can be cheap built in serie, much cheaper as per hand craft. It can also accomodate engines between 5.5 to 11 kW. By 10 hours of cheap, night electricity which cost in Poland 8 ec/1 kWh each unit can produce heat for: 5.5=280m2 7.5=400 m2 11>600 m2. It is by 250W/1m2 home insulation. By new of 55W it is over 4x more of place to heat. In kW of warmth it is respectively: 7/7.7  9.8/10.8  15.5/17 The last dates are after workhead insulation to 99%. Normally, without isolation, first values for effective heat are. Electricity power consumption: 7.5  9.9 14.9  In Amps its: 12 16 24          Each engine runs at 75% of nominal power, but real eff. for electrical motors is not very over 50%. The first Siemens progressive motor serie had better values, but You know, crises:-( For example   real mechanical power to heat conversion is for 11 kW =205% For bigger engines over 22 kW it is even more. It rises slowly with power.     When electrical engines producers will alredy making as written 90% eff. work, it can be total 200% to be. Aber Papier and Internet hat Zeit... By small serie of production units cost is: 5.5/7.5 2600 Eur  11=3100 Individually it costs +30% Fe. 18 kW which produces 31 kW of heat =9000 E. It is even cheaper to buy 2x11 units + steering for 1000 to have power of 18 kW 1800E. cheaper!               DRJ1000. 11 will cost probably 13.000 E. It can produce 》110 kW heat.          DRJ200.5 is not very good really. It is cos of small power, very water quality gently. It can have not enough power to break water continuity and consume more electricity as specified.  7.5 is an equivalent to 34 kW gas burning machine, 11 equals 56 kW installed power of gas machinery.                                   Real economy as for Poland. Coal 26.000 KJ =190 E./1 T it is to 3 times cheaper. By gas of 0.45 E. it is over 2x cheaper. By day price of electricity of 0.13E. it is only 25% over gas and 2x times over coal.     To make it all run properly, you have 2 x 300L bottle for proper heat production to heave.
Dr Adolf Nowak
Quote from: Dr Adolf Nowak on December 11, 2010, 12:13:35 PM
This reactor of 350%(total >200%) It will be replaced in 3 years with new 400/600 series with total over 200% eff.
This DRJ350X was built for evaluation purposes only. Standard DRJ200 series runs on motor with 2900 rpm. To achieve the best heat production by same nominal power of electrical motor it should be at 3500 rpm driven. By such velocity it should to even 50% more of heat to give. But please compare voice of DRJ200 with noice (Larm) of DRJ350X. (when this 2nd film goes not on please search on YT). Whats over, this 350^s is only at 3100 driven. By full 3500 rpm^s noise of nuclear reaction can only to supersonic fighter flying over head compared to be.        For 1 home it is not really intended. Such machine can only to be placed alone in special building or deep under ground level. We have started with new project 400/600 (real 350). But cost est. 》100.000 E. is. It f. e. by 11 kW engine should give more power of 200.18 unit with less electricity consumption. It should give some 180% total eff. But yet we have to end more bombastic^s exp. so it have to wait:-)
hartiberlin
Hi Dr. Nowak,
is it something simular to a Griggs pump where the overunity energy is coming from
the sonic fusion where water bubbles are collapsing ?
So the output of your machine is pure hot steam
and then you use it to heat water with it in a room radiator heater?
Many thanks.
Regards, Stefan.
shylo
this guy is full of shit ........its nothing more than a vawt,........vertical axis wind turbine.........shylo
