HHOHHU.com HHO heater. Is it overunity ?
Started by hartiberlin, February 06, 2009, 12:59:24 AM
pmazz850
I just experimented with the copper tube heat exchanger and my little HHO torch and it does produce a fair amount of heat. I got the tubes to 160 degrees in about 20-30 minutes with a 1 inch flame. and when you lightly blow through the tubes it puts heat out the back of the pipes. I like the heat exchanger. Simple yet effective!
pmazz850
Ramset,
What produces poisonous gas? I've never heard anything about burning hydrogen and giving off poisonous gas. With some simple mods the system could be vented.
ramset
PMAZ
If you use an electrolyte  you are not using pure water
And you get poisons
Yes venting is required
Chet
Thanks Grandma
woodpecker
@hartiberlin,  as i sad, i needed about 260 Watt for about 3 liters.
I can produce the gas with my drycell which i introduced in the "Drycell goes to Austria" thread.
I wrote there in Oktober, that the cell reaches values over faraday.
For this heater, i already cutted some copper tubes, to try it out. I will write soon about the exteriment.
@ albator 10, in the copper tube there is just steelwool, ( it should be bronzewoll but i could not find that) very pressed, and a little bit of water,i saw this in a video at youtube, and it seems, it works, you would need about 3 liters of gas /min. The more gas the better. I have two bubblers für security reasons.
You can find hundreds of videos at youtube
ramset
All the link to Woodpeckers thread
          http://www.overunity.com/index.php?topic=5788.40;topicseen
                        Chet
Thanks Grandma
