HHOHHU.com HHO heater. Is it overunity ?
Started by hartiberlin, February 06, 2009, 12:59:24 AM
helmut
Quote from: woodpecker on February 08, 2009, 03:05:04 PM
Certainly a good idea, to diffuse the great heat of the HHO flame with these coppertubes.
For me it does not look,as they need so much gas.
Have a look at my picture of a HHO flame and compare it. For this flame i had about 3 l/min 260Watt
woodpecker
This is a very impressive flame.
With 260 Watt
Das ist echt eine dicke Flamme
Komm bitte mal nach Overunity.de
Dort ist die Heizung ebenfalls ein Thema.
helmut
pmazz850
The only thing I've ever read about poison being given off, is if you use water with chlorine in it. What if you use distilled water?
Quote from: ramset on February 08, 2009, 09:29:13 PM
PMAZ
If you use an electrolyte  you are not using pure water
And you get poisons
Yes venting is required
Chet
hartiberlin
Quote from: pmazz850 on February 08, 2009, 09:12:33 PM
I just experimented with the copper tube heat exchanger and my little HHO torch and it does produce a fair amount of heat. I got the tubes to 160 degrees in about 20-30 minutes with a 1 inch flame. and when you lightly blow through the tubes it puts heat out the back of the pipes. I like the heat exchanger. Simple yet effective!
Does the flame put more heat out with the copper pipes than without them ?
What about putting stainless steel wool into them ?
Will this absorb the heat better and produce more heat output ?
pmazz850
Didn't try the steel wool. I don't think you'll really need it. Its pretty effective. With a normal size torch flame they will give off alot of heat. My torch only gives off about a one inch flame. I will try a bigger flame and post back.
Mark69
This is a great thread.  What about using aluminum pipes?  Or would they melt?
@Broli and Chet, I am in too, if you want to put a collection pot together.
Mark
