ENERGY AMPLIFICATION
0 Members and 72 Guests are viewing this topic.
Qwert
If somebody has difficulties to get this patent, I can place it on Rapidshare. Anyway I see no restrictions accompanied to this piece on NASA site or any place else.
the_big_m_in_ok
Quote from: Qwert on September 20, 2011, 01:53:09 PM
@Qwert
You're right.  That report is unclassified.  I'm well aware of the NTRS server that's run by the Govt.
Here's the patent you referred to:
#4,275,317
"Pulse Switching for High Energy Lasers"
http://www.google.com/patents?id=G1w6AAAAEBAJ&printsec=frontcover&dq=patent:4275317&hl=en&ei=9yJ6TvnNMO3YiALnhs2qDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CC8Q6AEwAA
(Look at Fig. 1)
There's also this:
#4,707,619
"Saturable Inductor Switch and Pulse Compression Power Supply Employing the Switch"
http://www.google.com/patents?id=QlMyAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
(Look at Figs. 1 & 4)
The thing they have in common is that they have what amounts to an upper and lower rail with saturable inductors in parallel to both.  Additive magnetic amplification increasing away from the input, down the length of the rails, is what I believe the inventors/designers wanted to accomplish.  If so, that's what the circuits should do before they're triggered.
Some of the reference Assignee agents/companies are defense contractors (Northrop is one), so this should be old news, since it's a public patent on the search database.  I'm confident the latest circuits are classified, but we won't see them.
This is my OUR.com Bench thread devoted to patented circuits, voltage multipliers and power supplies along the lines of this subjects.  Lots of different kinds of devices.
http://www.overunityresearch.com/index.php?topic=1082.0
(Look at posted Reply #2)
--Lee
TEKTRON
Quote from: the_big_m_in_ok on September 21, 2011, 02:04:47 PM
There's also this:
#4,707,619
--Lee
Lee, the above patent lays out most implicitly that the N=windings would be the same on each stage of the toroids. BUT WHY??? What would happen if you doubled n=windings on each consecutive stage? Would this not only double the voltage and also current in each stage? I don't have the resources to try. Anyone want to give it a try?   :o ;) ;)
Qwert
Looks like Tito killed this thread. It's my try to revive it.
Why not to try to rummage Tito's posts and answers he received? In his last post Tito gave us a clue:
Quote from: Tito L. Oracion on September 15, 2011, 11:54:57 PM
i actually wrote this secret in one of my post in this forum but everyone is unaware. i guess no one is luckily absorbed that one.
There is a post, to which Tito never refers later again. Only Magluvin responded to it, but I guess, he refers to somewhat wrong object. Here is the link to the post: http://www.overunity.com/index.php?topic=6763.msg265783#msg265783
and here is the link, which (I guess) the text of that post refers to (only seven pages pdf with some illustrations):
http://www.fluxite.com/WorkingRadiantEnergy.pdf
I am here to cheer up. This is the only useful thing I can do on this forum.
SkyWatcher123
Hi folks, Hi Qwert, thanks for posting those links.
I seem to recall a video by the guy from magnacoaster, showing what looked like a dead 12 volt car battery, he then hooked this battery up to a small inverter and the inverters low voltage cutoff kicked in when he placed any load on the inverter.
Then he connected his, what i assume was a radiant charger device like Ossie C. describes in that pdf, to the dead battery and this time, the inverter is able to power all sorts of loads without the low voltage cutoff turning on.
Seems like both setups are very similar.
The question is, was magnacoasters 12 volt battery just discharged or was it completely sulphated like Ossie C. recommends.
These two device setups, magnacoaster and Ossie C. radiant collectors i think are genuine.
I also think those battery capacitor/ultra capacitors probably have very similar function to these dead or sulphated batteries and how they are able to convert these radiant energy pulses into usable excess energy.
peace love light
tyson
