ENERGY AMPLIFICATION
0 Members and 110 Guests are viewing this topic.
Dave45
I figured you had something in mind
I have a pwm I got from rmcybernetics
If you run across a schematic please send it my way
Im a dummy when it comes to the electronics, but looks like its time to learn.
dave
Tito L. Oracion
Quote from: Magluvin on August 24, 2012, 12:13:54 AM
Sorry Teets. Its too vague. But I think you know that already. ;]
MaGs
No buddy, just use the tesla kicking tech.  :D
Tito L. Oracion
Quote from: Dave45 on August 24, 2012, 07:30:49 AM
I agree Tito it is dangerous but how can we get free energy to the world if we cant show them how to make it.
The ignition coil schematic I gave a link to is not a good candidate to do testing with, if you found the right coil configuration the power it would put out would be explosive.
Im removing that post.
dave
yes! that is what we are aiming very long time ago, the silent explosive.  ;D
roll
roll
roll
;D
PARAV
Quote from: Magluvin on August 24, 2012, 06:26:12 PM
Hey Dave
Thanks for the good words. ;]
If you wind 2 input or primary coils together and put them in series, and on that center tap connect B+ and use mosfets to alternately pulse the ends of the primary with -V then one coil will induce one way and the other coil will induce the other way. They use this method in car amplifier power supplies.
Driving the mosfets can be done with a PWM IC, many available and freq adjustable.
You can use a flip flop IC to switch the fets, with a 555 timer set to 50% duty to trigger the flips and flops, while the freq of the 555 is also adjustable.
MaGs
Hi MaGs,
Thanx for being there with your suggestions on  Dave 45's ideas---Can you show us a rough schematic of what you think, of how this could be wired up----Thanx again--Paul
Magluvin
Ill figure out something to work for you. What freq range do you want to work with? Input voltage? And what is your idea for a primary coil, as in no. of turns, wire size?
It would be good to have some base lines so when I design the circuit, we are in the area you want to be, the first time. ;]
MaGs
